Boost Elbow
Yup! Allow more air through and open the wastegate sooner.
If your looking for ability to control your boost level....Try a MBC; manual boost controller. Even the cheapest ones work well...allowing 1 psi at a time increase, if desired.
I use the cheapest JoeP model...works very well.
http://www.boostcontroller.com/
RJ
RJ
With you HX-35 Turbo, anything over 35+/- psi boost is just over heated air and higher EGT's....but no more HP. Boost Elbow may take you too high. But if your wastegate is set to open sooner (HX-35's are set at 21 psi...you may gain power and reduce smoke by increasing it up to a higher level, without going over 35 psi.
RJ
RJ
RJ
RJ
Plus lower EGT's if the turbo stays inside the efficiency range!!! It worked great on mine!!
~Nick
Personally, I don't want any more "Stuff" in the cab. Once I have the MBC adjusted where I want it....I see no need for change on a regular basis.
Mine is mounted on the line between the turbo and the wastegate...no real need for a bracket.
Your choice where you want it.
RJ
RJ
dodgediesel
14
12-14-2006 10:54 AM
TorqueJunkie
15
08-30-2006 10:15 PM
RockcrawlingTJ
07-22-2006 06:11 PM
triplenickel
08-23-2005 05:01 PM
Palmetto_kid
01-16-2004 03:21 PM
