boost elbow
Old 10-18-2009 | 10:42 PM
Dieselboy1155's Avatar
boost elbow
So i have a 99 5spd with a power puck other than that it is stock. will adding an adjustable boost elbow make iny differnce in performance or do i need to buy a boost fooler
Old 10-18-2009 | 11:13 PM
matthais's Avatar
Every little bit helps. What year truck?
Old 10-19-2009 | 12:13 AM
MadDog01's Avatar
The boost elbow will help. I would imagine that the power puck has a boost fooler built into its software. I've used and Edge easy and I'm now using a Van Aken, they both have boost foolers built into the software. Good luck.
Gary
Old 10-19-2009 | 12:16 AM
Dinner's Avatar
His truck is a 99.
I'm not sure if the power puck does boost fooling or not. So first off find out if it does or does not. Once you know that, than you can decide on what you need to help out the extra fuel. In both cases though, with the added fuel..the little extra boost will help out with power. If the puck does boost fooling all you need is the elbow. If the puck doesn't fool, then you will need both a fooler and elbow.
Old 10-19-2009 | 07:45 PM
i've read a little on it and as far as i can tell now it doesnt have a fooler built in. so i guess thats the next purchase on my list
Old 10-19-2009 | 10:32 PM
matthais's Avatar
being a 99 vp I cant stress enough in getting a good lift pump and fuel psi guage, you dont want to run that vp pump dry $$$$
Old 10-22-2009 | 12:41 AM
MadDog01's Avatar
Yes! Make sure you have gauges. I went through three lift pumps!!! I had gauges, I saw that my fuel pressure was failing and replaced the pump before any damage was done to my VP44. I now have An AirDog 150. LP problem is gone.... I'm still on my original VP44. Knock on wood..
Good luck
Gary
dodgediesel
14
12-14-2006 10:54 AM
TorqueJunkie
15
08-30-2006 10:15 PM
RockcrawlingTJ
07-22-2006 06:11 PM
triplenickel
08-23-2005 05:01 PM
Palmetto_kid
01-16-2004 03:21 PM
