Boost Bolt
Boost Bolt
I bought a boost bolt here at DTR and in the Peformance shop its says: "Simply replace one of the intake plate bolts for easy access to boost pressures." Would someone have a diagram of where that would be or has anyone already bought this bolt off this site and installed it? Thanks for the help
I've got one and installed it in place of the second bolt back from the front of the truck, next to the valve cover.
Just be dang sure not to over torque it! The torque spec is 12 ft-lb.
Heres a pic from a 3rd gen, I hope the manifolds are close enough to help out.
http://www.dieselmanor.com/dm_products/DM-BSTBLT.asp
it is a bolt that goes into the intake manifold just behind the air horn. look a few replies down in this thread:
https://www.dieseltruckresource.com/...d.php?t=176617
I have a picture of which bolt to use
Evan already nailed it....but here it is again:
https://www.dieseltruckresource.com/...hp?photo=17388
You can also drill and tap the intake horn for free.
FordTrax
04-18-2014 09:47 PM
moparmatt
04-25-2007 03:13 PM
