Boost
Old 01-28-2005 | 08:40 PM
CODODGE2500MAN's Avatar
Boost
What is it? Is it good or bad? What readings should gauges be showing for good scenerios?
Old 01-29-2005 | 01:24 AM
mkubacak's Avatar
Boost is gooooooood!!! For the most part, more boost equals more air. More air needs more fuel and that means more power. You can get too much boost though. I believe your '98 auto has a HX-35 turbo. Anything more than about 38 psi would be bad boost. You would just be pumping hot air into the engine past that point. I am not familar with the predator, so I do not know if it has a boost fooler or if it adjusts fueling and timing of the fueling.
When your truck is stock, you will throw a code if yo exceed the factory boost limit. Probably around 20 psi. If the predator has a boost fooler, it will let you exceed that limit. Cruising down the highway you should see 8 to 10 psi.
Michael
HOHN
45
10-08-2005 09:51 AM
triplenickel
08-23-2005 05:01 PM
GTSDave
07-08-2005 10:06 AM
MY WORLD
25
12-29-2004 09:54 PM
Palmetto_kid
01-16-2004 03:21 PM
Quick Reply: Boost
