Bombing the 47RE
i believe there are to many variables to make a clear answer.what would be the use of the truck?every day driving,drag racing(high boost launches in 4x4)sled pulling,pulling heavy loads?....and a great deal of the answer lies in how much line pressure you plan on running.some aftermarket vb`s run like a 65/140 swing,and some ,like mine,run more,like a 85/160swing.....i believe the more pressure you can run,and still have your seals hold in there,the better holding power you will have,and the more hp you can run.this is the whole basis of dtt`s builds,simply making sure you hold the pressures up by the use of better sealing throughout the tranny.....................bama
Originally posted by TPilaske
Your best bet would be to contact the vendor of your choice and tell them what you want to do and see what they recommend.
Tony
Tony
First of all you'd need to diagnose your real linepressure and leak test your tranny. The lower rpm of a better TC will increase the effects of any small leak you have now.
Without a leak test it's a game of chances.
AlpineRAM
AlpineRAM
Originally posted by Dr. Evil
sorry.....I meant for normal highway/town driving with a very occasional light tow (under 5k)
Have a pressure test done to the transmission to check for leaks in the seals and if every thing is fine then a VB and TC should be good to go for 350 Hp. Remember there are no guarantees in life no matter how much you do to some thing, it can still break.
Tony, I just thought Id throw it out there.....lots of very knowledgeable people here.
Yes there is a pile of knowledgeable people on here... but tranny questions always seem to go south fast... well at least they used to anyway...
Re: Bombing the 47RE
For you auto guys,
How much HP can you run with just the valve body and torque converter??
For you auto guys,
Opie
I had my AT modified with a BD heavy duty valve body and Torque convertor at 75K. I have since towed our 10,000lb 5er all over this great country with only one problem. A seal blew at 125K, strangely enough while running empty. The local Dodge dealer had the truck 3 different times and never did find out why the AT would not upshift from 2>3 when cold. One trip to my local Cummins repair center and they replaced the seal with a thicker one BD now uses. I would not try to upgrade my 47RE again. ATIS manufactures AT's guaranteed to withstand 350HP with a 2 year unlimited mileage warranty. Check out thier link on the DTR home page.
