The Bomb Bug has dun bit...
As the subject sugests... The BOMB bug has dun bit me... My first investment - Gages...<br><br>I have come to the wisdom of the DodgeDiesel.org forums for enlightenment (and also diesel-central). <br><br>What should I get, where should I get them, and what price range is fair to say I'm not getting ripped off! <br><br> :-* :-* :-* :-*<br><br>Thanks for your help!
Re:The Bomb Bug has dun bit...
Yeah what Jamie sad ;D Rod is da man 8) Straight shooter, good to do business with and he's allways glad to share his knowledge with us rookies
Decide which line of gauges you like then proceed. EGT, Boost, Fuel Pressure are the three you need to look at getting.<br><br>Some people like digital, some people like analog, its a matter of choice.
sweet deal - I'm thinking the analog will be sufficent - and along the lines of EGT, boost and fuel pressure were what I was after - but is there anything else - without overdoing it of course
If I read you sig correctly (manual 5 sp.), those three should pretty well cover it for you. If you have an automatic, then a trans temp guage would be advised if doing any towing at all.
[quote author=MYTRNx3 link=board=7;threadid=15063;start=0#141454 date=1053721614]<br>Yea, I have a 5 speed manual <br>[/quote]<br>I was just reading your sig. you might want to do some digging about fueling boxes. Not too long ago, the bullydog torque dog was a re-badged diablo power puck. then I heard BD went to Edge and that the TD was now an Edge box. But my point is that if the bomb bug has bitten you should consider the fueling box that will satisfy that bite. the power puck may not satisfy you long term! Anyway, there are many out there to choose from and a few really good ones. You should discuss that with Rod too ;D
I am switching to digital gauges, they are easier to read and record the low and high to be checked at a later time. Maybe I am getting too old to read the analog gauges. I suggest start with digital and there will be no need to change later on.<br>Bruce
Good deal - keep'em comming.<br><br>As far as the post on the TorqueDog - If there is any one person to bag on them - then I will invite you to drive my 100% stock truck with out one - then with one. The difference is comparable to frankenstin coming to life. I seriously needed to be held after gettin on the throttle in 2nd gear... <br><br>Basically my turbo usually spools and kicks in at around 2200rpm (or where I get the benefit from it) With the TD started spooling at no more than 1700. The difference - WOOOOOOWIIE! I am sold, and won't be told otherwise. <br><br>My rig is a daily driver, to have that extra power at my disposal from such a simple little ole box... Takes my breath away...
iker42
32
09-09-2007 02:48 PM
own1bigtruck
02-15-2007 05:21 AM
YinYaker
11-10-2003 12:28 PM
