body lift or suspention lift?
Old 03-11-2008 | 12:12 AM
Red_Angus's Avatar
i have an 97 ext cab long box. im not looking for alot of lift, 2-3 inches, i think. i just want to get the diff off the ground. i will probably be doin mostly mud bogging. the roads get that bad when its wet. i think the biggest tires i want to stick under her are 33s. so do i lift the body or the suspention. i think the body lift is cheaper. alot of the guys here seem to have put massive lifts under their trucks. what do u do with those trucks? how does it effect your daily driving? did u have to do any other mods? i had heard the of u go over 2". u have to extend the steerin linkages. i havent done anything like this to a truck before. any imput would be great.
Old 03-11-2008 | 12:24 AM
Buckshotram's Avatar
33" will fit stock under the truck, with a 2in leveling kit you can clear 35" tires. A body lift looks bad and is alot of work on a dodge.
Old 03-11-2008 | 12:26 AM
Patriot_Auto's Avatar
I would suggest the suspension life. Yes it cost more, but its is worth it. Replacing your ten year old suspension will make your ride much better. You will gain suspension travel and flex.
IMO body lifts are a cheap way to go. They don't always look good.
Old 03-11-2008 | 12:30 AM
dieselpup's Avatar
You could level out the front with 2 inch spring spacers. That's plenty of room for 33's. I think maybe even 35's with some rubbing.
Old 03-11-2008 | 12:36 AM
Crimedog's Avatar
You'll be able to clear 33's right now without any issues. If you wanted to run 35's you need either the 2" leveling kit or body lift and you'll most likely have a touch of rubbing with the wheel turned and stuffed. You can ovoid this by dialing in the perfect backspacing, but I haven't found it yet.
Old 03-11-2008 | 01:52 AM
bullboy85's Avatar
body lifts are for show. they never really look right eather, if ur gona use it dont go with a body lift. like everyone elce said though, for 33 no lift needed.
Old 03-11-2008 | 09:08 AM
high bid's Avatar
The 4" skyjacker system is pretty good. Only 1 problem, the trackbar drop bracket...not enough support to the frame. Installed w/Bilsteins longest shocks and it almost drives like a caddy.
Old 03-11-2008 | 10:47 AM
olddodgetruck's Avatar
3'' spacers from top gun customz rear add a leaf with 315/70-17s on 3rd generation wheels with olmost no rubbing only on the lower control arms. i fixed that with a set of 3rd gen control arms. they bolt right up.
Old 03-11-2008 | 11:37 AM
fmxr47's Avatar
i put a body lift on my 99 and the leveling kit, i will never do a body lift again, its more hassle than its worth, sire they are only $170 from summit, but you also have to modify the inter cooler tube and your fan shroud is only gonna be mounted at 2 spots on the top. go for the gold and get suspension or the spacers, i would recomend the spacers, they are about a 4 hour install with a buddy to help move the axle around
Old 03-11-2008 | 04:56 PM
JIT's Avatar
JIT
Just get a leveling kit and the tires and you'll be fine with 33's!
Old 03-23-2008 | 10:18 PM
Red_Angus's Avatar
ahh ok. sorry it took so long ive been in the bush for the last little while, they finally let me out.
with the bigger lifts from skyjacker and such is there a lot of mods to the steering componts and trackbars and stuff?
BoDiesel
07-24-2014 10:06 PM
justin allan
01-09-2012 11:23 AM
Trooperthorn
01-07-2011 01:55 AM
jj3500
07-12-2009 04:59 PM
H2SRDMB
09-07-2006 08:00 PM
Quick Reply: body lift or suspention lift?
