bluechip pump cover yes or no
is the blue chip cover worth the money it is a pretty ice looking product but is it really worth the money i would like to have something better than the schotch connector but didnt know if it is worth the money.
I ran one for a while and had issues with connection as the temp changed in the pump.
Some have cracked the circuit boards with these as well.
I recommend soldering the wire, leaving it a bit long with a protected spade connector on the end. It makes it easy to shorten or repair a bad end if necessary and is the best kind of connection.
Dave
Dave
These are the absolute best no cut/solder connectors I have ever used. I think they now come standard with Edge wire tap boxes also.
http://www.posi-lock.com/posiplug.html
Genos garage sells em too.
I have one for 2 years now and it works great. I can see how you could break a circuit board if you do not follow directions. Follow the directions and it will work fine.
97CTD
01-14-2003 08:47 PM
