blew the boot to shreds
well i got a g tech meter this week and when i was trying to play with it i blew the lower right front boot. yea the expensive one. i think it should have held 60 psi just fine. well the hole is the size of my fist. and i am planing on reworking it to use a straight peice to make cheap replacements. so can any one tell me the size of the ic piping and what size the inlet to the ic is? or do i have to pull my truck apart and find out?
I just went out and measured mine , inlet side of the boot is 3" and the outlet side appears to be around 3.75".
Crawl under your truck for a few seconds with a caliper and you should be able to get at the inlet tube of the intercooler to make sure , without taking anything apart.
brandon.
95black2615
10-08-2008 03:34 PM
