Black Smoke
Old 12-13-2006 | 12:37 AM
Ol'Red's Avatar
Talking Black Smoke
Others have it and I want it what's the best way to get it?
Old 12-13-2006 | 12:40 AM
dieselfan's Avatar
FUEL and more FUEL!!!
Old 12-13-2006 | 12:42 AM
n0ne's Avatar
fill out your sig.. and we can tell you.. what truck do you have.. what year.. etc etc..
Old 12-13-2006 | 01:03 AM
Ol'Red's Avatar
I have a 2001 2500 4wd 6spd
Old 12-13-2006 | 01:24 AM
n0ne's Avatar
well you can go with an Edge Hot Juice chip w/ attitude monitor since you don't already have guages.. or you could go towards a TST fuel only box and a Smarty for timing which is the best power stack anyways.. that'd do the chip part.. and then pair that with some injectors.. and a bigger turbo.. and then watch your stock clutch go bye bye.. so replace the clutch too.. and then you'll have a mean machine ;x But any chip by itself will really give you some smoke..
Old 12-13-2006 | 01:54 AM
Ol'Red's Avatar
what is a TST fuel only box?
Old 12-13-2006 | 01:57 AM
n0ne's Avatar
like.. the TST PM3 Comp ... doesnt do anything with the timing.. just adds extra fuel.. by tapping into your VP44 wire.. and then a smarty will add a Catcher ECM flash for more additional fuel and its timing software.. for even more unf..
Old 12-13-2006 | 10:47 AM
mxdsl183's Avatar
get a edge comp...i love mine..but you need gauges
Old 12-13-2006 | 11:35 AM
blackdiesel's Avatar
Registered
if you want smoke get a old used edge comp and run it with the map sensor unplugged. Then get you a set of 150 hp jammer nozzles. This will produce the most smoke for the least amount of $$$
Then a clutch, and a turbo. Gauges first of course
Old 12-13-2006 | 12:30 PM
RowJ's Avatar
http://www.tstproducts.com/
RJ
Old 12-13-2006 | 12:32 PM
RowJ's Avatar
Or just floor it in 6th gear at 1,000 rpm!
RJ
Old 12-13-2006 | 01:16 PM
dodgezilla04's Avatar
wrap a trash bag around the air filter!
RJOS
16
09-03-2007 10:19 PM
BuildingBoost
03-25-2007 08:46 PM
BlackSheep5
11-27-2006 08:52 PM
bensdad_canada
05-09-2005 11:56 PM
dhe9
11-14-2003 08:31 AM
