BIlstein shocks and Daystar leveling kit ?'s
I have a 1998 2500 4x4 24 valve QC, Long bed CTD. I am installing the Daystar spacers and I hear from some that longer shocks are needed. Can I get some educated feedback from anyone with the same set-up that uses their truck offroad and not just a pavement pounder ? No disrespect, but I drive through Baja often and I tend to get the full extension of my shocks on a regular basis. I don't want to end up with the wrong front shocks. I already have the BE5 2550-HO's on the rear. Bilstein hasn't gotten back with me yet so I have turned to the next step. I am getting the T-Rex suspension lift next year but need to do this for now. Thanks for any feedback.
Please help......truck needs to be put back together.
FWIW, i inquired the same thing back in the spring. This was the reply I got from a dealer I emailed:
Phillip,
BE5-2549 is the front shock, BE5-2550 is the rear shock, however with a 2" lift, neither of those part numbers will help you. For a 2" lift front in the front, I would recommend part numbers BE5-6681-H5 (front) and BE5-6682-H5 (rear). Unfortunately, the fronts are on a national back order and are not expected to be available until March. The rear shocks can be ordered at
http://www.bilsteinshocks.com/bilste...ocks.asp?make='DODGE'&model='Ram%202500'&year='2001'
Thanks,
Kevin Foote
kfoote@ allshocks.com/turnermotorsport.com
Turner Motorsport
(978) 388-7769 x60
good luck!!
Phillip,
Thanks,
Kevin Foote
Turner Motorsport
(978) 388-7769 x60
good luck!!
RobV2500
01-20-2009 12:04 AM
RobV2500
01-18-2009 05:44 AM
WOT Racing
55
05-09-2008 10:09 PM
rjm022
20
01-04-2008 11:50 AM
kry226
01-29-2004 07:09 PM
