Which Bilstein shocks
Ok everyone, after what seems hours of reading, still can't figure out what shock i need for my truck? i guess the ? is, i have a leveling kit, so can i use the HD (blue/yellow) or do i need to go with the 5100 series? Looks like the part # that bilstein is listing is 2549 frnt/1908 rear. is this correct? And i'm guessing thats the HD shock. And then it shows 6681 frnt/ 6647 rear for 2" lift. Isn't the leveling kit 1.5 inches, i believe thats what mine was. So can i use the 5100, or do i need the HD. I tow a 26' boat, and a 30ft 5th wheel in the summer.. couple of tons of hay here and there. Thanks for any info.. My tour in Hell (iraq) is finally over! i'm on my way home as i type this.. should be stateside by mid week!!! Thanks for supporting the troops!!!
Capn
Capn
BUMP... oh come on guys, with everyone running these shocks no one can drop me a note on this??? HMMMMM.. And now just to add a little bit, just saw in a mag that there is an adjustable shock for diff. lifts?? Any info on this one?? Thanks for ANY info...
Capn..
Capn..
Most "stock" shocks can be ran with a leveling kit. The Bilsteins you cannot. Many people have reported trying to run them with taller springs and complained of a harsh ride that's attributed to no more travel in the shock.
That's sorta right. It's 2549 FRT, 2550 REAR.
I can't verify the HD part numbers, but I will say that with spacers and/or springs you'll need the HD shocks for the front for sure.
2549 frnt/1908 rear
I am running the Bilstein 5100's with my 2" taller springs up front. Really like how they feel. Don't know the part numbers. If you need them, I will try and find the receipt.
~Rob
~Rob
check the website for specs or call them. I run the largest ones they carry but after just checking it looks like they have even larger ones.
http://www.bilstein.com/mistore/ymm_...reYMM=storeYMM
Thanks for the info guys, I'll be making an order real soon, so on that note, where is everyone finding the cheapest prices on these? Well i'm back in the states after a yr deployment, but looks like i got here just in time for the hurricanes!! I'm in Norfolk right now, trying to get back to MT.. this weekend will be interesting i'm sure!! Thanks for supporting the troops everyone!!
Capn
Capn
so if i have a leveling kit, the 2549/2550 i just received in the mail are the wrong ones for the front? i've been debating about removing the leveling kit... this may force me to remove
You could try them, but a lot of people have claimed the ride was harsh with those particular Bilstein's. I wanted to get 2" lift springs for the front, but I wanted the shocks with a lifetime warranty. The 5100's have a 30 or 90 day warranty, which is not sufficient for me living in the salt belt. Maybe someday I can add my spacers with them if I go south, but for now I'm stuck at the stock height.
WhoCares79
11-09-2009 10:54 PM
rjm022
20
01-04-2008 11:50 AM
StealthRam
03-08-2006 04:19 PM
