Billet VS Stock shaft difference
Old 01-31-2007 | 10:47 PM
ratsun's Avatar
Hey guys is there any way to tell the difference between a billet input and output and the stock ones when looking at them while installed in a trans? So if the trans was out of the truck sitting on the floor would they be distinguishable somehow?
Old 01-31-2007 | 11:57 PM
Fred Swanson's Avatar
Input is easy to spot, look at the splines where it stabs into the TC. Output not as easy. Usually, you can see the color of the metal and tell.
Old 02-01-2007 | 08:46 AM
ratsun's Avatar
Thanks for the reply Fred
Could you be more specific as I don't have both side by side to compare. Is the billet shinier or duller, and what difference am I looking for at the splines? Thanks
Old 02-01-2007 | 09:59 AM
Timinva's Avatar
DTR Advertiser
Input the outside diameter of the splines should be the diameter of the shaft. Output look at the radius where it goes from shaft to gear, if it is a right angle it is stock, if it curves or blends into the gear it is a billet. DTT / IE shafts are a silver/bright steel in color. I have seen other brands of inputs black or grey. Tim
Old 02-01-2007 | 10:37 PM
ratsun's Avatar
Good stuff Tim thats helps allot.
If this trans has shafts they would be IE shafts so hopefully I will be able to tell from your info.
Old 02-02-2007 | 12:20 AM
12valve's Avatar
BEING A NEWBEE IN TRANNYS...
HOW FAR DO YOU HAVE TO TAKE THE TRANNY APART TO TELL?
I bought a whole used BD tranny... it works fine, just have no idea what the innards are, xcept a BD tq converter
Old 02-02-2007 | 10:25 PM
ratsun's Avatar
12v
If I understand Tim above you you shouldn't have to take the input apart but it sounds like the tail housing has to come off. I hope to get a look on Tues and see if I can figure it out. I don't know about your neck of the woods but the BD out here (Abbotsford, B.C. )doesnt do to much in the way of billet shafts...
D45
02-02-2010 09:05 PM
blackcloud
06-15-2005 10:13 PM
4x4
22
04-08-2004 04:40 PM
