Billet intermediate shaft or not?
What kind of power will the stock intermediate in a 47rh hold up to. Mainly daily driving, and hauling tractors/hay through the summer, but I will also be doing a fair share of sled pulling, and drag racing. Im guessing the most my truck will have for a long time is gonna be 500hp, since a 2.5 charger is probably as big as I will be going, but I want to be able to drive it how I want, and not worry about it. I will be talking to Dave Goerend about what he thinks I will need, but I think here really soon, my tranny will be getting built
After 50k miles of well over 600ft lbs of torque, and locked shifts, I believe the clutches have FINALLY had enough. I dont know the mileage the tranny has on it, but its been a great one in my opinion. I havent been easy on it in the least. Heck it still daily drives great, and I wouldnt be afraid to hook it to a load, but at WOT it doesent shift good now, and the converter wont lock under hard throttle either. I drive it in Valet mode every day, and running it hard in valet it shifts fine, so im guessing the extra power in full fuel is finally getting to it. Anyways. Do I need the billet intermediate or not? Cant wait to have a black tranny between the framerails![CoffeeTime](https://www.dieseltruckresource.com/forums/images/smilies/new1/coffeetime.gif)
Eric
Eric
Ran 11.40's @ 790hp, Stock Intermediate, and C-Hawk ran 11.76 #2 only with stock Flex plate and Stock Intermediate Shaft Their strong only person that I know of thats broke one is JoeFarmer trying to lite his charger with Nitrous on the line.
Thanks guys, If I can get by without spending that $650 for the billet intermediate, then it will be quite a bit easier for me to afford the tranny
But, If I thought i needed it I would go ahead and do it.
I WILL be doing locked shifts. Anyone think this will cause a problem? Are any of you running locked shifts, and running 11's? Thanks!
Eric
Eric
Eric
Eric
I have always locked up converter after 1-2 shift with no problems on 2-3 shift. No bogging or apparent serious load doing so on my DTT (That's what they told me and that's how it feels).
Also have stock intermediate shaft.
RJ
RJ
When I bought my tranny it was explained to me by the installer (a diesel performance shop) that they mostly see broken input shafts, very seldom see a broken intermediate or output shaft. I ended up installing a billet input and flex plate along with Goerends complete tranny. This tranny is awesome...
With twins you might not get the bog locking up early like with a single, but i know Chris tried locking his in 2nd and could't get any better times that way always right after the 2-3 and alot of it has to do with the style of converter your running.
I don't think the bog is as noticeable on the already tight DTT converters. I lock mine right after it shifts to 2nd and the shifts don't feel any harder than normal. Theres not as much rpm change as the triple disc style converters. Probably not near as much to be gained on ET by locking the DTT converter as the triples either.
I broke my output shaft on an easy 10 pound launch. My truck pulls 1.78 to 1.83 60 foots on a 10 pound launch in 4X4 and that was all it took to snap it.
I know of quite a few broken output shafts. As I've had it explained to me before, at least you lose it, you don't tear the rest of the tranny up, and I don't believe you have to drop the tranny to change it.
At least you don't have to change the whole tranny like you do on the NV5600 either.......sniff, sniff.....
