Billet fuel cap
Billet fuel cap
When hooking up to the cap form Genos do you need to install a swivel fitting of some sort, so you can take the cap off to change filter without twisting hose, would you need banjo bolt, Also how long of hose to reach steering column mount.Thanks I have learned alot from all you, but i could not find this in the search.
I ordered one of those caps and then got to thinking about changing my filter and then called and cancelled the order. They said you would have to disconnect the gauge to change the filter which would be a major pain. I went with the banjo bolt on the bottom of the canister and saved myself some $$$$ too.
D45
02-02-2010 09:05 PM
darrenb
04-17-2007 12:44 AM
GOT BOOST?
04-02-2007 04:57 AM
TDIwyse
01-16-2005 12:02 PM
