Biggest tires on a 3500
Old 11-12-2002 | 12:28 PM
97CTD's Avatar
Re:Biggest tires on a 3500
I would go to you local tire shop and see what they say we have some good ones around here but i guess 2hrs is a little bit of a trip just for tires!!
Old 11-12-2002 | 01:07 PM
ToolManTimTaylor's Avatar
255/85/16 BFG Mud Terrains .... Love 'em .... Load 'em .... Burn 'em
Old 11-12-2002 | 04:33 PM
willyslover's Avatar
Cattle Hauler..on yours being a 99 the 235 is max unless you change the rims to the 01's....might I suggest you look at the Mich. XPS in traction...a little pricey but a damnn tuff tire..steel sidewalls that do not flex on loaded conditions [and I know you run loaded regularly]..better handeling in the mountain roads also as the don't roll over on the edges..takes a few miles to break them in as they feel like your on your finger tips till they lay down..but well worth the extra $$ IMHO..got 60K moles out of mine an I drive it like a slot car in the mountains I live in...I do not wear them out I grind them off..the first set of factory Mich. I got 25k on for compairson..[this was on my old rig 98.5..have them now on my 01 also.]
Old 11-12-2002 | 09:31 PM
Hired Gun's Avatar
I wonder what a set of rims would cost?
Old 11-12-2002 | 10:22 PM
Stroke This 24V's Avatar
A Friend of mine David Gresh has 285/75/16 on his dually and drives it a lot when it is together
Old 11-12-2002 | 11:06 PM
Redleg's Avatar
[quote author=Cattle Hauler link=board=7;threadid=6945;start=15#65980 date=1037149332]<br>Thanks all, I guess I will havd to settle with the 235', don't want to put money into rims. :-[<br>[/quote]<br>I just went with Cooper Discoverer A/T 235 85R16. Look nice, aggressive tread, and E-rated. I think you'd like them.
Old 11-15-2002 | 07:10 PM
pappyman's Avatar
95 3500 with 235's hauling gooseneck with 18000 lbs tires are close to rubbing on hot days on hot highways...over all happy with the tread wear...next I will try the recaps I have on my casings.<br> Pappy
Old 11-25-2002 | 03:49 PM
GDeitrich's Avatar
CH been there done that. I'm still hunting for heaver tires for my 98.5 Dodge. My problem is that it is not a duely. Your best bet is look at the Richson sight (www.ricksontruck.com). He is pushing the 19.5 wheels. A good tire for you would be the 225/70R19.5 in 12 or 14 ply. Duels are 3415# &amp; 4300?per tire and only 32' dia. This would only be .2 more than the 265/75R16. And this is the smallest tire he has. They go up from there. My problem for me is he has the only single rear wheel that I can find. For you there are a lot of people who make wheels for duels.
05-29-2009 11:24 PM
sakisaki400
23
12-31-2006 11:17 PM
G-NOTE
08-23-2005 09:00 AM
rattle_rattle
14
04-15-2004 07:52 PM
GreenMachine5.0
03-25-2004 08:18 PM
