biggest(most coverage) fender flares for 03
ok i am very frustrated with my truck throwing up these rocks and that are scratching my factory paint. this paint is just rediculus, little rocks 1/4" diameter and putting scratches 3" long on the sides of my truck....i need a fender flare with alot of coverage, or whatever sticks out the farthest! they also have to look good....anyone have any suggestions.. its for a 2003 dodge ram 2500..
p.s. i dont care if i have to take the cummins sign off i know a better place for it anyways
Re:biggest(most coverage) fender flares for 03
You will probably want the Bushwacker Extend-A-Flares. They aren't cheap, but look good when painted to match your truck color. Mine are being installed right now and I will have some pics in a week or so. Check 'em out...
www.bushwacker.com
www.bushwacker.com
I have used BUSHWACKER flairs before, they fit nice and are still around. Warn use to make a 4x flare, I'm not sure it they still produce them? The ones I used were the extend flares, thats probally what you would need, only thing bigger is the cut-out flares.
i wish they made the cut-outs for my truck i had them on my old ford and i love them...i could run tires that were 4 inches taller!
I have Bushwacker Extend-A-Fender's on my 2002.
They stick out almost 3 inches, giving that much more stone deflecting coverage.
I didn't have much choice, as my rim and tire choice sticks out 3 inches.
Now for some mudflaps that give the same coverage, if not for me, the poor soul behind me on a gravel road, or in the rain even.
Pics in Members Photos, page 20.
I chose to leave them black, but they can be painted to match easy enough.
phox
phox
The Bushwacker cut-outs for '03 Dodges are nice. They are basically the same as the extend-a-fenders, except they have pocket cut outs for stainless bolts that are just for show. There is no cutting or driliing to install the flares.
I painted mine to match my, truck, a picture is on my website.
berak on the back fender of your truck it doesnt look like it fits perfect. is this just the photo or does it really have a gap between the body and the fender?
That's just a shadow from the crappy picture. They don't fit perfect from the factory so you want to spend a few hours sanding / filing to get them as close as possible. How much time you spend doing this determines your results.
I may have a 1/16" gap in spots but all in all it's pretty good.
Guest
Posts: n/a
Yeah, they are just right for me, but that's because they don't appear to stick way out. My 315's appeared to stick out ~2" beyond the sheet metal. These flares extend a solid inch past the tires and don't draw attention as sticking too far out, they look OEM. Good luck in your search, due to the extra flare at the bottom, Warn's flares "look" wider.
Eddy Reyes
32
06-05-2007 07:36 PM
Fisherguy
04-13-2006 09:17 PM
