bigger turbo?
Old 10-18-2005 | 12:36 AM
rebal's Avatar
Question bigger turbo?
what size housing is on a 2001.5 HO whx35 is it a 12cm or 14
the reason i ask is i would like to keep my banks brake but need a little bigger turbo
Old 10-18-2005 | 01:04 AM
oestreich84's Avatar
All the 2nd gen 24 valves that have a manual trans came with hx35's and a 12cm housing. The 2001 and 2002 automatic trucks came with the hy35 and the 9 cm housing.
Old 10-18-2005 | 10:14 AM
BigBlue's Avatar
I just put a KSB-1 on my truck with much smaller injectors than yours and a comp and it's real nice. Hardly any noticeable lag, TONS of top end, great street manners, it's the best of both worlds. Even when I have the comp on 2x2 it spools great. It would work great with your catcher and 1.6's if that's all you have on there. This turbo is probably best suited to the 400-450hp and under crowd. On my setup, I dynoed 371hp and at a sustained 117mph my EGT's are 1220-1250*. A lot better than 1500* by 80mph.
Old 10-18-2005 | 08:12 PM
rebal's Avatar
[QUOTE=BigBlue It would work great with your catcher and 1.6's if that's all you have on there. This turbo is probably best suited to the 400-450hp and under crowd. On my setup, I dynoed 371hp and at a sustained 117mph my EGT's are 1220-1250*. A lot better than 1500* by 80mph.[/QUOTE]
the EGTS go up real fast so im thinking bigger turbo I have hit 1200 but had to back out cuz of speed...(90 +) I have a max boost of 35psi and im wondering just how hot it will get towing 23k? will that turbo let me keep the exhaust brake? and who sells them?
Old 10-18-2005 | 08:23 PM
BigBlue's Avatar
My roommates HO with a comp and mach 1.5's could easily hit 1500* pulling 3k if he ran the box on 5X5. I would imagine that you could hit the same. The KSB-1 would probably be a good upgrade for you. I don't know if you could keep your exhaust brake though. The KSB-1 has a full 4" exhaust outlet and needs a full 4" down pipe. Have you looked into getting a scotty 2 intake to help keep things cool?
Old 10-19-2005 | 12:25 AM
rebal's Avatar
I have an afe mega canon on it but still have the stock exhaust -muffler. I wonder if I got a 14cm housing from HTT if it would work both EGT and brake
R & A Equipment
02-27-2007 12:27 AM
VikingDiesel
116
08-02-2006 06:50 PM
glowball
12-20-2004 12:38 PM
hialtitude
11-06-2004 07:54 AM
ramguy
20
09-03-2003 12:35 PM
