Big Injectors
I am not sure what the BIGGEST injector would be for a 95' Dodge CTD 12 valve, but I know that Scheid Diesel can make just about any injector you would want for one including ones that are ABOVE 20 thousandths in hole size. Their toll free number is: 1-800-669-1593. Ask for J.P. and he will help you out. FWIW, and to give you a "comparison" the 370's are 5X.013 and as I recall the stock 95' 12 valve injectors were 5X.009 (9 thousandths).
John_P
John_P
Ideally I would like a set of 5x.015 That would be slightly bigger than a New Erra 430's only problem is I don't believe that they are off the shelve injectors. In fact I'm not even sure they can be made but I do know that they would give you slightly more fuel than the 430's.
Shaders 24v
08-11-2003 10:18 AM
