Big Honkin Air Filter??
Ok then the BHAF is out what would be a step up and economical being on a tight budget I need to do somthing because I know I don't have enough air with the K&n the filter minder keeps poping and the filter is clean..
We've had lengthy threads on teh BHAF around here before. Bottom line is it's a mild airflow improvement that still filters well, but it's not flowing much more than stock.
That, and you give up the cool air draw of the factory box, so the BHAF might be a step backwards.
I'd try an AFE Pro Dry or another DRY filter.
jmo
jmo
When towing my egt's went up 150-200 deg when I added a bhaf, the turbo sure sounded good though. After a 200 mile drive I went back to the stock box and a napa filter.
I think what I might do is keep the k&n and swiss cheese the air box with a hole saw. Then again I would rather buy somthing better if I can find somthing on the board? Anyone have a decent setup that there looking to part??
Probably just the filter sucking in the heated air around the turbo. I am assuming you didn't use a heat shield?
My Egt's dropped about 50 with the BHAF. I wasn't really going for performence gain, my K&N was just dirty and I also wanted a better sound. And the sound is so much better, so BHAF gets my vote for a cheap nice upgrade.
May want to check out the Amsoil universal dry airfilters Part number Eaau 4510, 4515, several sizes to choose from but the 4.5" ID works best to hook up to the turbo inlet hose. I had the K&N w/the factory box cheezed and noticed oil being sucked into the turbo. An easy change w/plenty of air...about $70 total vs. $200+ for other aftermarkets.
NICE_N_EEEZ
08-28-2010 09:33 PM
sapper043
0
06-13-2010 10:36 PM
MmmDieselFumes
08-03-2007 12:22 AM
