BHAF trouble, clamp slips off
Old 07-15-2008 | 01:26 AM
cLAYH's Avatar
I've gone back to the stock filter box and filter. For the third time I've found the hose partly off where it clamps onto the filter. I know the clamp was tight. I wonder if its because there is no lip for it to grab.
Anyone else experieince this?
Old 07-15-2008 | 02:49 AM
Dr. Evil's Avatar
Did you mount the filter onto a chunk of ABS?
Common problem if you are mounting the filter directly onto the hose.
Old 07-15-2008 | 11:03 AM
dieselscout's Avatar
mine is on a piece of 4" exhaust. works great.
Old 07-15-2008 | 11:46 AM
cLAYH's Avatar
Hmm no I didn't. The hose fit nicely over the filter outlet so I just clamped in on there. Ok I'll pick up some exhaust or ABS. That will actually work well as it will give me somewhere to mount my sprauge tube for my propane injection.
Thanks!
Old 07-15-2008 | 10:03 PM
phox_mulder's Avatar
I've had a BHAF for 60K miles, actually 2 during that time, and have never had one slip off the hose.
I've had both the Fleetguard one and the Napa one, both have stayed connected just fine.
hpox
Old 07-15-2008 | 11:17 PM
Danderson's Avatar
Thanks!
I had 4" ABS on my BHAF setup on the '99 and had to retighten it every few weeks also. I could never figure out why it wouldn't loosen up on the stocker?
Old 07-17-2008 | 11:41 AM
NorKal12valve's Avatar
take a piece of 4" exhaust tubing and slice a piece off about 2" long and it will press into the inside of the filter then clamp your hose around the filter as normal, and tighten it up!
pooperscooper
05-18-2009 09:54 AM
Bad Ramer Jamer
12-27-2007 10:32 AM
guzzirider
19
07-20-2004 05:53 PM
Chrisf
07-07-2003 12:25 AM
tcb
06-24-2003 09:25 PM
