BHAF Part Number
BHAF Part Number
Well, to save me some hastle I'm gonna need a part number. I'm thinking of going Fleet Gaurd so if you guys could help me out here it'd be much appreciated.
Thanks, Mike
Thanks, Mike
From Tech Facts:
Fleetguard AH19037
NAPA 2790
WIX 42790
Donaldson B105006
Baldwin PA2820
Hastings AF1012
AFE 20-40044
Carquest 87790
John Deere pmah19037
Big A 93790
Caterpillar 3i0005
Fleetrite ahr819037
Luber-finer laf2531
Fram ca6818
UNI 908
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Fleetguard AH19037
NAPA 2790
WIX 42790
Donaldson B105006
Baldwin PA2820
Hastings AF1012
AFE 20-40044
Carquest 87790
Big A 93790
Caterpillar 3i0005
Fleetrite ahr819037
Luber-finer laf2531
Fram ca6818
UNI 908
Originally posted by PaulG
Standard Fleetguard BHAF is AH19037. Marine version Fleetguard is AH19004.
Marine version is water resistant.
Slightly different filtering media which results in different flow and filter rates than the standard Fleetguard,
but I can't remember the differences off hand.
phox
phox
The difference is about $50 more for the marine version.....
Get yourself an outerwares prefilter (like Phox's) instead....:
https://www.dieseltruckresource.com/...sort/1/cat/500
Found the info below on another. the 04 flows about 1/3 more air than the 37.
With the 37 (marine version) do you think the prefilter would necessary?
Houw muck air flow loss is incurred using the Outerwears pre-filter?
PRODUCT INFORMATION
Part No : AH190370
DEFINITION AND MAIN DIMENSIONS
Part Type AIR FILTER HOUSING
Configuration HOUSING
Flow Direction OUTSIDE/IN
Part Function HOUSING
END OPENING HEIGHT 1.38 in
END OPENING INSIDE DIAMETER 4 in
OVERALL HEIGHT 11.88 in
HOUSING OUTSIDE DIAMETER 10.5 in
FILTRATION, MECHANICAL SPECIFICATIONS AND TEST STANDARDS
CAPACITY 825 g SAE J726
INITIAL EFFICIENCY 98 % SAE J726
FINAL EFFICIENCY 99.9 % SAE J726
RATED FLOW 687 ft3/min
PRODUCT INFORMATION
Part No : AH1900400
CAPACITY 830 g
RATED FLOW 918.19 ft3/min
HIGH TEMP 235 F°
LOW TEMP -20 F°
HIGH HUMIDITY 98%
LOW HUMIDITY 1%
PRODUCT INFORMATION
Part No : AH190370
PRODUCT INFORMATION
Part No : AH1900400
CAPACITY 830 g
HIGH TEMP 235 F°
LOW TEMP -20 F°
HIGH HUMIDITY 98%
LOW HUMIDITY 1%
1generationkid
05-28-2013 04:24 PM
