Bhaf!
Old 02-26-2008 | 03:38 PM
btown647's Avatar
Bhaf!
i would like one and i have i need to know where i can get one. and how to install it i have a list of part #s for them. but i would like to know if i can walk into advance or napa and get one any help would be much abliged.
Old 02-26-2008 | 03:44 PM
fmxr47's Avatar
napa has them in stock, i dont remember the number though.
Old 02-26-2008 | 03:49 PM
xtoyz17's Avatar
www.fleetfilter.com
Should be able to get it for $50 shipped or less IIRC.
Old 02-26-2008 | 03:53 PM
btown647's Avatar
thanks now how do i install and is heat sheild a must
Old 02-26-2008 | 04:06 PM
xzaq103's Avatar
Remove the stock airbox. The Bhaf slides on the intake tube. i just let it sit there on my 98.5. As for a heat sheild i would say no. I never had an issue with not having one.
Chris
Old 02-26-2008 | 04:12 PM
HOHN's Avatar
The NAPA P/N is 2790, IIRC.
I paid $60 for mine back in the day.
Old 02-26-2008 | 05:06 PM
high bid's Avatar
install a cut rubber hose over the a/c line that the filter rest on....if not it will wear thru the aluminum line and you'll loose your a/c freon.
Old 02-26-2008 | 07:27 PM
afoulk's Avatar
You can get a Donaldson one from Vulcanperformance.com for $38 and some change. The heatshield isn't a must, but I made one anyways and painted it with high temp paint. I also cut a piece of old mudflap out that I got from work and laid it on my fender so that the filter didn't rub through the a/c line or the paint on my fender. Vulcan also has the Outerwears pre-filters for the BHAF too if your interested.
Old 02-26-2008 | 07:39 PM
btown647's Avatar
thank you much
Old 02-26-2008 | 07:43 PM
blitz_81's Avatar
about hopw long do they last.I have had mine on for about 10k and it looks pretty dirty. was wonderin how long ya'll leave them on for.
Old 02-26-2008 | 07:51 PM
xtoyz17's Avatar
Mileage may vary, biggest thing that helps is a filter sock over it to catch a lot of the bigger stuff. Mine has 10k and looks new still.
Old 02-26-2008 | 10:39 PM
hink's Avatar
A heat shield is not a must, but my EGT's went up about 75 degrees across the board even with a heat shield installed.
Old 02-26-2008 | 10:46 PM
Vern Calhoun's Avatar
That's wierd, my EGT's went down almost 100 degrees at WOT, and that's with my 100hp injectors. Different strokes for different folks I guess. Just my 2 cents.
Vern
Old 02-26-2008 | 10:49 PM
hink's Avatar
Vern
That's kinda the general consensus I had read before installing mine, so I was surprised to see them (egt's) go up instead of down.
Old 02-27-2008 | 02:13 PM
btown647's Avatar
where can i pick up a prefilter or can i make my own?
