bfg's at's 285/16
Old 01-07-2005, 06:35 PM
dansdodgediesel's Avatar
bfg's at's 285/16
I just bought a set of BFG's At's today. They didn't have the 265's so I got a good deal on 285's, I really don't know if I like the bigger tire's. Seems to sway more and work the truck harder with more pulling around on the snow that was on the side roads today. They sure do look good on the truck. Better than the 265's I'd say. I took a set of Firestone's Wilderness's off 265's. they were too light of tire and half gone. What do you guy think of the bigger tire's? I 'm a littler worried about millage falling off. Thinking about taken them back.
Dan
Old 01-07-2005, 06:39 PM
mr T's Avatar
mileage in town will go down a tiny bit on the highway it will go up
how did u like the 265's?? did they look proportional in ur opinion? i have alimited budget and im about to get a good deal on 265's im runnin 245's would the 265's be noticeable?
ps 285's will be nice on the dodge...that should be stock factory size for dodges
Old 01-07-2005, 09:20 PM
Citizen's Avatar
When I bought my truck it had 295s on it and recently I put 305s on it. Really looks great and helps fill out the wheel well.
Old 01-07-2005, 10:01 PM
Dieselcamper's Avatar
I have a 2 wheel drive with LT265/75R16 now and I
think they look too small in the wheel opening. I'm going
to move up to LT285/75R16 this weekend. Sears is having a sale
on General Tire All Terrain LT285/75R16 for $109.75 ea. Has anyone
used these with good results ?
Old 01-07-2005, 10:11 PM
93w250's Avatar
My truck had the bfg 285's on it when I bought it. It seemed to wander alot, like the sidewalls flexed too much. When they wore out I put Yoko 245 75 16's on. I went with the smaller tire to get a little more pulling power. It handles better and doesn't wander any more.
Old 01-07-2005, 10:27 PM
ratsun's Avatar
I'm on my second set of BFG AT 285s and love them. Sidewall flex on any bigger tire is a issue if you like the hard ride from 80psi in a 10ply. The taller tire will cost you some milage in town but you should make up for it on the hwy.
Old 01-07-2005, 10:35 PM
Dr. Evil's Avatar
very true...I definitely didt like the ride with the 10 ply LTX's....the 295 grabbers I put on ride and perform GREAT. Couldnt be happier (well maybe if I went to 315's).
Old 01-08-2005, 02:00 AM
dodgeram's Avatar
I found I have to run my 285 BFG's at 60lbs+ or they flex like crazy and wander all over....
also I still get 22mpg with them on the highway with the cruise set at 2000rpm
Old 01-08-2005, 03:38 PM
DaNuGuy's Avatar
bigger, wider tires will wander more, esp in the snow. They leave a bigger footprint. If you live near Pa, maybe we can work a deal for those tires?!? Email me at hamyscj@dejazzd.com if you want.
Old 01-08-2005, 04:10 PM
I may stick with the 285's. I would like to get a set of factory Alloy wheels for it. at least then they would be on a 8 inch rim and the rims wounldn't run out. Right now there's 5 ounch of weight on both side of the rim to get them to balance out.
I went out and played in a snow pile today. Them things work great!!!
Dan
Old 01-08-2005, 04:33 PM
ratsun's Avatar
Dan
__________________________
From what I have read the factory alloys wont fit your truck, I'm not to sure what the problem is but there has been a fair amount of discussion on this topic. I would look into some more before shelling out $$$$
Old 01-08-2005, 04:47 PM
Geico266's Avatar
With the 285's I noticed my speedometer is off by 5 MPH after 50 MPH. So be carefull out there.
Old 01-08-2005, 08:06 PM
I have heard you have to take some stock off the outside of the drum. I would like to know were and how much. I don't want to weaken the drum. I have a Lathe big enough to do the job. I really dislike the steel wheels. They don’t hold the tolerance’s that a turn alloy wheel does,
Does anybody know how much and were the stock has to come off the drum before I buy a set of alloys?
thanks
dan
Old 01-08-2005, 11:28 PM
eo1sc's Avatar
I have 285s Cooper discoverys on mine for the past 4000 miles mounted on stock chrome rims. I must say they handle great, ride nice, do throw off the speedo, and so far work great in the snow. So far I have no complaints.
Old 01-09-2005, 12:19 PM
ArcticWolf's Avatar
I'm on my second set of BFG AT (KO)'s and love them. This time around I also bought a set of wider wheels - American Racing "Baja" wheels - 16x8 and they work great. Only problem is some slight rubbing on the inner plastic fender (which I hate anyway - very poor design). I don't have problems with them wandering and they've always performed outstandingly in snow - I go up to Lake Tahoe quite a bit during the winter and have YET to need to add chains!
Dan, they fit the stock wheels with no problem at all, nothing needs to be done to the rotors or drums - they never rubbed against anything on my truck - if you look at my photo's you can see the half worn (1st ) set on it....
Quick Reply: bfg's at's 285/16
