Better Pics of MAP and Data Link
Old 03-21-2006 | 07:28 PM
Ridiculous's Avatar
i'm gonna be getting an edge ez soon and i was looking for better pics of the MAP sensor and the data link than what the one's given in the online instructions gave me. it'd be best if i can get a pic from someone with the same setup as me (check sig.)
and also can i get the instructions in layman's terms for me. maybe just sum up how you did it, cause i am unsatisfied with the instructions they give me.
well that's all for now
thanks ya'll
Old 03-21-2006 | 07:38 PM
firehawk's Avatar
Check out the info in this post. https://www.dieseltruckresource.com/...ad.php?t=93452
Pics on second page and a link showing the MAP sensor location on the first page.
Old 03-21-2006 | 07:45 PM
AggieJustin's Avatar
That link shows the location for the data link on a '99, it's in a different spot on the '02.
The MAP plug will be just to the rear of the fuel filter housing. It's pretty easy to find and easy to reach. The data link connector should be attached to the top of the bracket that holds your lift pump. It will have a plug end capped off. The cap usually looks like a plug with the wires cut off. Just pull the cap out and plug in your EZ there. If the plug isn't attached to the top of the lift pump bracket, reach right behind the LP and you should find it hanging there.
I'll try and get pics, just need to charge the camera batteries.
Old 03-21-2006 | 07:58 PM
Ridiculous's Avatar
thanks guys i appreciate the help and AggieJustin, i would love some more pics, you go on ahead and change those batteries and get them pics on here ya hear
wrangler04
06-03-2008 02:02 PM
Cisco
08-17-2006 10:24 PM
Patrick Campbell
09-10-2005 07:53 PM
orcaburger
09-18-2003 05:43 PM
drecu
12-02-2002 05:28 PM
