Best way to bleed FG guage line
OK. So no bleeding required. Got it. I just had the thought the like your brake system that if air is in those lines that the air will compress since brake fluid does not compress and give you soft pedal. I thought that applied to the FP guage since air could possibly throw off pressure readings.
My numbers are :
Idle - 9-11
Cruise - 6-8
WOT - 3
I got a dying pump. I plan on replacing it this weekend. The guage action is smooth and linear. The more pedal i give it the more the needle goes down.
Idle - 9-11
Cruise - 6-8
WOT - 3
Its a 3 beer and an hour job job for my "99". Remove the fuel filter housing and its alot easier. Be real carefull not to loose the sealing metal & o-rings, and don't overtighten anything. (or leave beer cans under da hood! ) Your numbers will be way up. Replace the fuel filter while you got the canister off.
Good luck!
Good luck!
jesussaves
11-15-2010 01:09 PM
Bad Ramer Jamer
13
01-12-2008 05:38 AM
TankerIP
04-05-2007 12:03 AM
robert chilton
09-13-2005 04:50 PM
