the best turbo!!!!!
Old 10-13-2009 | 07:39 PM
DodgenIt's Avatar
BD Super B 57/65
BD Super B Special, 64/71
I.I. Phat Shaft, 62/65
I.I. Super Phat Shaft, 62 or 66/71
Quite a differance between each one. They hop back and forth to cover all the reg sizes of a well known single turbo.
Old 10-13-2009 | 10:12 PM
matthais's Avatar
Thanks for the help good info
Old 10-16-2009 | 10:07 PM
Mike Holmen's Avatar
The Guru
My best single is the GT3788R or a GT3782R. They spool-up fast. They also work decent in twins configuration.
Old 10-17-2009 | 02:04 PM
busa's Avatar
Originally Posted by Crazydave
I run mach 4's and a HTT 62/71/14. Dynoed on 10-3 and it made 551 hp on a dyno jet. When you turn the box down, it is still decent work truck. On the really hot humid days towing heavy its a little lazy between shifts but manageable.
What he said, a 62/71 would be better for driving every day(quicker spool) but the 64/71 would be a little more fun if you don't mind smokey lag and give you room to grow.
Old 10-18-2009 | 02:52 PM
matthais's Avatar
cool advise I think im going to go with a 64/71 sps and get a cam.
Old 10-18-2009 | 06:59 PM
The Guru
If you where closer, I would volunter to give ya hand on the cam swap. Those darn tappets are fun to wiggle back into position and those rusty bolts on the bumper. The rest is pretty easy. Which cam you thinking about using? You running a P pump or VP?
Old 10-18-2009 | 11:11 PM
matthais's Avatar
Thanks, Its a vp I was going to go with a Fletcher cam. I havent done a cam swap in a cummins but I have on other diesels(cat, perkins, mits) I think I can figure it out I got some local resources.
Old 10-22-2009 | 02:13 PM
Mopar_Man's Avatar
I am running a Turbo Re-Source Custom Garrett GT3788R & love it, It spools very fast & I have had no problims with temps getting to hot.
Dodgewincity
15
06-12-2008 10:26 PM
Ada381
02-10-2008 08:58 AM
5.9Excursion
11-21-2007 07:50 PM
FMB
02-03-2007 06:34 PM
furious70
04-16-2004 08:45 PM
