Best Tuner
Best Tuner
I have a 1999 5.9 Cummins with a 5 speed that I am looking to get the best economy out of. I know a tuner is a good solution, but which tuner offers the best fuel economy? Are there any other less expensive mods? I don't do a lot of pulling, but I do on occasion and would like something that doesn't keep me from making power.
Your best fuel economy is driven solely by your right foot! My Juice box has an economy setting which I normally have it set at. Whether it actually provides and MPG's over and above what my right foot can deliver is unknown. It has a tow mode which I use whenever our 11,000lb is attached to the truck. Level three is called "driving" which adds more fuel and timing to the motor. Goes pretty hard, my "built" transmission snaps hard on the 1-2 shift and has broken the back wheels free from time to time. Great grins and hard on fuel and parts. Just a few thoughts. YMMV
Cheers!
Mike
Cheers!
Mike
How do you change settings with the edge ez? Do you have to shut the truck off and reload software like the smarty or what? Also can the ez and the smarty be stacked? If so what gains would you achieve? power, fuel economy, ect?
Sorry johnh but I'm not sure what you're asking me? The Smarty is about the same power as the EZ but with a lot more adjustability, and can be stacked. The Comp is about the same as the EZ until you tap the pump wire. Then the power is considerably higher and the stock clutch will never hold.
Yes, mild injectors do smooth things out and lessen the rattle noise a little.
Both the EZ and the Comp settings can be changed on the fly. The EZ has a small 3 position toggle switch and the Comp has a larger button type switch. Both are routed into the cab and mounted wherever you choose.
Originally Posted by Danderson
Some new RV275 injectors will buy you some fuel economy. Combined with an Edge EZ or a Smarty will yield a much more driveable truck.
Does anyone know if you can stack a smarty and edge ez or comp? I want the tire size adjustment of the smarty at the very least but it sounds like the edge comp or ez might be better for mileage....plus I really like the idea of on the fly adjustment. Anyone ever experiment with stacking these boxes? Or have a comp or ez they are wanting to Sell?
"Sorry johnh but I'm not sure what you're asking me? The Smarty is about the same power as the EZ but with a lot more adjustability, and can be stacked. The Comp is about the same as the EZ until you tap the pump wire. Then the power is considerably higher and the stock clutch will never hold."
that's what i wanted to know katoom, thanks
More Power
48
01-05-2009 01:15 PM
Moobesor
07-22-2008 11:05 PM
2001 CTD
06-30-2008 07:01 PM
Gear Jammer
19
11-09-2007 11:41 PM
loki1313
12-10-2005 09:23 AM
