Best Leveling Kit
Best Leveling Kit
I am wanting to level my truck out. Is there one leveling kit that is better than another. What would you recomend to run up to 35's or 315. Probally just going to keep 285's.
PM member coRED and see if you can get some info from him. Coils from Coil Spring Specialties and Bilstien 5100's all the way around. coRED might have the part numbers, I don't have them handy.
I know he's pretty happy with the way his truck rides. Don't waste your time with the SJ D25's.....
I don't know what the brand is, but I personally have metal spacers and love them. I think they're even better if you ever plan to get a lift kit, that way you don't blow even more money now on springs that you'll wind up not needing later. Leveling kits are pretty cheap. Anyway, here's a vote for the spacers.
i got the polurethane and i think their good, no problem slightly smoother ride.
Hey Aggie Trailcutter RT's are the best tire in the world!!!!!!!!!!!!!!!!!!!!!!!!!
Originally Posted by johndeere1259
hey do u happen to know how much those tires run in a 285 70 17
I had 285's. After the lift they really looked "stock". Looked like the 265's did on the truck when new.
My 285's tread was down to 2/32nds anyway, so I went with 315/75/16's Toyo A/T's. Moderately agressive tread but just as quiet as the Michelins I had. Like the ride...love the look! They do rub a little in full lock turns.
RJ
I'm leveled with a Daystar kit, Bilsteins in all four corners, and the 325 Toyo A/Ts (35/13). Love the stocky look with the tires, and they only rub at full crank. I've had no problems with this set up. But leveling does push the track bar slightly out of alignment.
One of the lessons I learned after installing D25 springs was caster and camber. I had to max my adjustment on the eliptical cam to be even close to stock. After replacing my lower links with Skyjacker links, I was able to place the frontend forward in its stock location and keep the cam nearly centered. Anything greater than the leveling springs, I would also replace the upper links. Movement of caster and camber affects steering and tire wear. I attempt to keep this measurement within factory specs.
sgtdiesel
25
06-26-2012 02:37 PM
JOECUMNS
03-18-2007 10:15 PM
subspd
20
02-11-2007 09:49 AM
ocsurf16
21
09-11-2006 11:05 PM
CASMOKIN
16
11-01-2004 04:09 AM
