Best Fuel setup for my application
I know, I know it's been asked a million times before. However, with my sig. which one should be the best? The only other item that will be added is a dif. turbo once the stock Holset goes. Right now I have 15psi @ idle and on 5x5 WOT can pull it down to 6psi or so. I'm sure my Mach's are going to pull it down further. My choices are scotty, vulcan or fass? Combine a pusher pump w/my stock and a scotty or vulcan line kit? What about walboro? I am uneducated in the fuel system field....
You don't need upgraded pumps or anything until you get into biggish power. A scotty fuel kit is plenty adequate.
I can't get mine below 11psi with a Smarty and M4s-- on the factory LP. Works for me!
Originally Posted by B.A.Ram
that's just with a scotty system? How hard is the install?
I can't get my pressure below 10 at WOT (don't have my 1.6's in yet, those will be next weekend). Prior to the Scotty's system, I was around 5-6.
Install is very easy and straight forward.
~Rob
thanks Rob. I should have my Mach's in this weekend so I guess I will buy a Scotty's for install on the 20th. You think I can take a "hit" off your smarty @ Sedalia????????????
I sure hope it doesn't get "vin locked" to my truck
~Rob
Yup. High idle still sticks as far as I know. It's a thank you present for trying it. Mine should be ordered beginning of next week so I'll have it for the meet. Fuel systems are easy. A 6 pack of shiner is all I ask.
Registered
Originally Posted by Tiger Rag
If you try it you are going to want one! You've been warned!........
Wonder if the high idle still sticks? I'll do the fuel system as long as someone tells me what to do. Should be a fun meet...
~Rob
