Best CTD build up????
Hi i have an 02 dodge ctd and want to build a very fast/ powerful truck and i want help/ guidance on what to buy and where to buy to get the most power bang for the buck. I know i have to do a tranny and am saving up i think im just gonna do a rebuild i also want to do a smarty, but other than that i just have ideas for a turbo, injectors, so on. Every little bit will help me and i know that you guys all have your own knowledge to push me along so thanks in advance!!!!
a full set of gauges(fuel press, boost, egt, and tranny temp) a lift pump, head studs, edge drag comp stacked with your smarty, f1 Mach injectors( I will be going with Mach 4 but you can go bigger), port polish fire ring heads, a set of twins, traction bars, water meth, 5" exhaust, I am no expert by any means but this is a set up that I am trying to achieve
You are wasting your time if you try and make big power on a stock transmission. The motor might be making it, but even a rebuilt stock transmission wont put anywhere close to all of it down. Get a GOOD transmission built. I reccomend www.goerend.com . Then once you get that, you can go crazy with the motor.
What's in my sig is good for 12s in the 1/4 and 20+ mpg on the highway and is very daily driveable. However there are better options out there now for turbos. A 64/71/14 would probably make a better charger. I would like a 62/71/14 in place of my sledpuller 66 so I can use it in twins later.
'Flatbed' covered it pretty well.
I would add a FASS type fuel pump and I believe the Adrenaline from Quadzilla will do as well as the Smarty/Drag Comp boxes... once they get all the kinks worked out of it. And, the Adrenaline will replace the need for the four gauges...if you don't mind digital instead of analog.
5" exhaust is optional but sounds great.... 4" performs as well up to 700 hp.
As stated, tranny should be first. Twins are the only way to go, IMO, with a heavily fueled auto. If you are like most of us, you will add fuel (hard to resist) before you invest in a bigger turbo setup ...... so be sure to keep your little factory turbo under 32 psi boost as you climb the HP mountain.
Also, do yourself a favor. Add only one thing at a time. It makes any trouble shooting that might be needed much easier.
RJ
RJ
I would also go with the adrenaline. I think it is a good set up with a few bugs but they have been working them out and they stand behind their stuff.
I also like the digital gauges.
THANKS ALOT FOR THE COMMENTS!!!!! When i say a tranny rebuild i mean a whole performance billit tranny no way am i gonna try and put any power to a stock and i like the idea of the adrenaline too but i also did hear that a smarty stacks with a tst??? or somthing along those lines was the best but i cant remeber what the chip was called but i love the help
I had a Smarty stacked on a TST Comp for three yrs! It's a great combo.... and prices should be lower on the used TST's...now the Adrenaline is out.
BUT, the Adrenaline is the only box I've tried that made a full (rated) 180 hp on my auto. And for a Smarty/TST you will pay a lot more and get no gauges. Adrenaline is coming out with custom tuning that may make the other boxes obsolete... if Quad can eliminate the surging issues we beta testers are dealing with now.
'Kid77' - Welcome to DTR. Fill in "signature" ...under "User CP" in the header. It than posts your truck info so we can give you better informed answers!
RJ
RJ
thanks again the adrenaline sounds siick but should i wait to buy because of the bugs??? i already had a chip, dual 4" exhaust, and injecors planned before snow and as i said im waiting to sell a few things for the tranny build up but all this is a great help thanks again keep posting
What are you going to use the truck for? Is it going to tow? Race? Sledpull? This all helps determine which parts are going to work best for you.
if ya wanna go on the cheaps for the injectors...i am pleased with the jammer nozzles i have now. if u want bigger power get the jammer 5, but you will need a bigger turbo. just look in my sig. its a perdy good but its incomplete...i need a turbo and a tranny. i had my smarty for 20,000 and now the trans slips going in to od and 3, the tq shutters bad at some times. i cant tow with it right now but in about another month i will get a suncoast trans.
Hey thanks for all the posts i want to use it for ocassional pulling such as a car or landscape stuff but mostly race even thought a sled puller would be sick not as practical
The Guru
For an all out rig, go with 6.7L, twin CP pump and twin turboed. Of course there are a few details left out but, it would be one sweet ride of a truck. Nice daily ride too. I bet you could pull 700 rwhp, day in, day out. You just need a decent transmission to handle that 1200+ lbs of torque, daily.
bone8=8machine
04-08-2006 02:49 PM
mrwaters
12-28-2005 10:11 PM
clarkoh
08-15-2005 11:43 PM
