Which is best, bigger injectors or fuel box for more fuel?
Old 01-18-2008 | 07:59 PM
MikeR's Avatar
In all the trucks I've owned or even built for other guys, 100hp injectors work better than a 100hp box. Better driving characteristics, egt's, and injectors have always been kinder on the fuel system.
Old 01-18-2008 | 09:27 PM
Tommy93w350's Avatar
A homemade boost fooler is simple. Get a small pneumatic regulator and plumb it between the map sensor and head. I can't remember the fitting sizes, but seems they are metric and a pain to find. Anyway, turn the regular setting low so the map sensor never sees over 18 lbs of boost.
I used the clear type pneumatic hose with push lock fittings
Old 01-19-2008 | 01:08 AM
NoSeeUm's Avatar
Originally Posted by HOHN
I'd like to go from having a mild performing truck to a monster, just be flooring the pedal.
More air and a fueling box, you're just about there....
This describes my truck to a "T". That is why I am not using the Smarty, I often like no smoke in the mild mode. OTF adjustability is very nice.
Jim
Old 01-19-2008 | 09:07 AM
J Lent's Avatar
Jim
How does the XZT+ compare to the Smarty using the TST stack?
Old 01-19-2008 | 01:24 PM
redbull01's Avatar
i have both but before i did i jus had the edge drag comp and i liked it because u can turn it off if u wanna
Old 01-19-2008 | 05:49 PM
HOHN's Avatar
Jim
It sure is. Right now, I have the "monster" part down pretty well. It's the "mild" part I'd like to improve.
I also don't like smoke--- at all. ULSD seems to help reduce smoke a bunch, but I can't say for sure since I've only driven my truck in bitter cold temps on winterized fuel, where smoke is unlikely anyway.
I wish Quad had a TST-type box out right now. I like his XZT+ from what I read of it. I don't think he's making the Xzillaraider anymore (in favor of Adrenaline).
Maybe I'll just do the XZT+.... and upgrade to M6s That might be cool. Can a person break 500hp without a wire tap? Not likely unless you spray. Anyway..
Sorry for the OT.
JH
Old 01-19-2008 | 08:25 PM
This is good information, thanks guys
Old 01-19-2008 | 08:45 PM
BigB82789's Avatar
A HRVP, big sticks, and a xzt+ might do it. Since the HRVP is useless with a wire tap, might as well do this. I think there is one person on here with a similar setup.
Old 01-19-2008 | 09:01 PM
Ph4tty's Avatar
With mach 6's and a silverbullet, yes its been done =P
STROKETHIS1
12-21-2009 12:18 AM
LanceD
05-21-2009 09:10 AM
Bradleysram
19
05-12-2009 09:36 AM
madhat
09-01-2008 05:00 PM
R & A Equipment
02-27-2007 12:27 AM
