Best 12V Injector
Best 12V Injector
Im looking to get new injectors for my 97 this summer and was wondering what yall thought would be the best injector for light towing and good gas milage?
Originally Posted by TxDiesel007
Bargain wise
or if you are on a budget, go with a PDR 370 injector, for 400 bucks a set, that aint too bad...
Rick
Rick
Originally Posted by txdodge97
yeah im looking to keep my egts down but want to keep it cheap to. What do yall think about a 16cm housing with 370s and a 10 plate?
I run a 14cm and it helps
now i can speak from experience tho, I pulled cattle today with my truck for the first time at 16.5 degrees, My EGTs run cooler as well, its a tradeoff, i did lose some power on low end, but nothing that 370s wont fix... that 16cm housing you have will reduce your egts as well, just make sure u bump ur timing too. Im runnin a stock 35 with a 14cm housing...
Rick
Yep, timing helps alot. Another suggestion is to look into a GSK if you don't have one. This will help the truck alot and is a noticable differance, also helps towing.
yeah im going to get GSK and delivery valves when i get the injectors but first i need the money. This is also a 16cm housing thats non wastegated so i dunno if that will make a difference if its wastegated or not? Thanks for all yalls help to.
Id definately suggest gettin the GSK
a 4K kit is best, get it from garrett at www.blackclouddieselperformance.com, good guy and great customer service. If your truck is a 1997 and manual, you are already running 181 dv's stock, you might just need the better injectors and that larger housing, with an advanced timing, and you will be fine. Right now at 16.5 im runnin stock injectors, but i set it at what it is cause 370's will be in soon, and i mean real soon.... Wastegate doesnt really matter, id jsut go with the one on the turbo, you really dont need a wastegated housing unless you do a massive single or twins..
Rick
03CumminZ4X4
02-01-2008 11:15 PM
Russell_d
02-25-2007 09:12 AM
CTD2001
02-03-2007 01:30 PM
