Benefits of Stacking?
What are the benefits of stacking? I'm currently just running a PM3 and wondering if there is anything more to gain by stacking. Thanks in advance guys!
In your case, the benefits are big..... The PM3 is a dog down low, an absolute pig... stack it with an EZ and you will be much much happier.. Thats what I did. I hated my PM3 and was ready to sell it to some other slob, but then I saw on here about stacking with an EZ... SO i pikced one up used on Ebay.. Now its still not anything like a MAD ECM or anything, but it is MUCH MUCH better down low. Up top is about the same with or without the EZ.
Do it, you'll like it.
Kevin
Kevin
I would bypass the EZ and go for the MAD ECM. Does everything the EZ will do and more; and from all reports, does if better...with more responsiveness!
But either way...definately stack.
RJ
RJ
I stack the VanAaken c5 and the superchips on perf tow mode and if you think an EZ wakes up the bottom you need to go for a ride in my truck, there is no question that it gives it a big kick in the shorts, and I gained mpg too. In my application I don't like to rev higher then I need to and my truck pulls WAY harder at 1500 then 2700, it feels like it has about 300 hp and 3000 ft/lbs
trik396
03-29-2005 10:20 AM
hotdram
03-12-2005 10:56 AM
tobyw
03-03-2005 10:01 PM
rshelton88
11-29-2002 08:08 PM
