Bell tech lowering springs
Anyone here using the Bell tech 3" front 4" rear lowering kit? Want to lower my 99 dually, and now is a good time as I need to replace my Balll joints. Bell tech has the #'s on their website, just wondering how they affect the ride quality. The rear kit moves the front spring hanger and adds longer shackles, so that should not affect tyhe ride, just the front springs. Peace Murf
Sorry man, I can't answer your question. But I do have a couple gee whiz for you....do you tow heavy with your truck, is it a 4x4, and why do you want to lower a dually truck designed to haul/tow heavy things?
I could'nt imagine lowering mine...if anything a couple inches higher and bigger tires like 19.5's
Good luck with your project
There is a member on here that lowered his dually, looked really good. He seems to know quite a bit about that kind of stuff. I think his name is Jaime and he goes by the name hellotbone. You might want to Pm him.
I believe Jamie uses air bags to lower his ride. I have a Bell Tech kit on my 89 Chevy truck. The stuff is quality and does not affect the ride. You're not changing the suspension geometry, just lowering the body. After I installed the spindles, I did have to do some surgery on the lower arms to allow the stock wheels to reach the turn stops. ( I ran steel wheels in the winter) I used a MONDO angle grinder to trim a little edge off the arm. I don't know how Dodge attaches the hangers to the frame, but you'll need a cutting tool if they are riveted as mine were. I drilled the rivet out, then used a chisel to whack the head off. I did have a little interference between a bed brace and the rear shackle, but the grinding tool eliminated it quickly. BTW, you will need to remove the bed to install the spring hangers. I'll tell you what, I like a slightly lifted 4x4, but I love a slammed street rod. Hope the info helps. It's easy to do with basic tools.
nasty01cummims
06-30-2009 01:52 PM
marka
14
08-14-2006 11:02 AM
