BD twins, who runs them and how do you like 'em?
#46
Originally Posted by Dshiftff
Jegs was out of them, they have them on order from BD with roughly a 3 week wait. total was like 2940 w/shipping. Comes with new 3pc exhaust manifold a 5" downpipe.
The BD twin package comes with a 4" downpipe... but the 3 pc manifold is not included in the twins kit and is a separate $400+ item?????
RJ
#47
Same part number, Id say same kit.
According to BD.. #1045320 is for 98.5 - 02 24v's.
I don't know squat about 12v's so not sure what the difference is but you might want to check into it... depending on which part # you have ordered?
Not trying to be negative...just trying to help avoid unpleasant surprises done the road.
Good Luck
RJ
#48
Originally Posted by Rodram2002
.... are you talking high pitch wine like a stock 35 or higher?
Have not tested with & without Scotty II hole to see if boost or EGT's are different, but without the hole, and with a TAG, the turbo whine is very low!
RJ
#49
Registered
Originally Posted by rjohnson
FYI - Homeontheroad.org lists PN 1045320 for 94-02.
RJ
RJ
set.
#50
FYI - Homeontheroad.org lists PN 1045320 for 94-02. BD lists PN 1045310 for 94-98's????
Good Luck
RJ
Good Luck
RJ
HOTR.org is a little screwy on there sight.
No offense... but we're back to "almost sounds too good to be true".
RJ
RJ
only the 3rd gen kit comes with the exhaust manifold unless you order it.
#51
Excellent
I thought I got a pretty good deal on mine. Should have looked around harder.... but the truth is... after driving with BD twins for 60 days... I would pay full retail, if I had to!
I know you will love em.
RJ
RJ
#52
Originally Posted by blackdiesel02
That works out perfect for me! i have a 02 and i can get the 2900 dollar set from homeontheroad.org. And it will be the same as the bd-power.com's 3700
set.
set.
http://www.homeontheroad.org/product...turbo-19942002
#53
Wow, looks like it does come with the exh. manifold. Here is an excerpt:
"The kit is complete with a SS X Intake, exhaust and intake piping, oil drains, heat shields and the 2003-2005 application even comes with a 3-piece pulse exhaust manifold to bolt on."
Wow, that is a deal!
#54
#55
Can't answer that...only other twins I've ever seen were home grown... with varying dergees of balancing problems.
I believe Piers racing twins are bigger, which means (just like single turbos) spool a little slower and pull a little harder on the top end.
The BD's are considered "smallish" as twins go...but I can tell you they work very well around 600 hp, and for heavy towing, will solve any EGT concerns at 500 hp and below!
RJ
RJ
#56
RJohnson Dynoed today with his BD's. 600+ HP and 1300+ FT/LBS!!!! OAT was 100*+ as well! He used his Water/Meth....but thats it. Not too shabby if you ask me.......BUT ill let him post his exact numbers on Monday......
#57
Well, I dyno'ed on the way to VA Beach to Timinva's to get my double disk clutch and hot rod VP44. Best HP was 534.48 & 977.88 TQ with Edge Comp 5x5 and Smarty on Sw8. Best TQ # was 984.46 TQ which yielded 517.13 HP with Edge Comp 5x5, stock ecm programming. This was with a dying VP that I was happy to make it to VA Beach on. HRVP and SB twin disk update upcoming......
I'll dyno again after clutch is broken in to see benefits of HRVP.
Twins kept it very cool on a hot day. Had to let it warm to op temp on each pull. Never saw boost over 50 on the dyno.
#58
But the 03-06 price is $3795
#59
Registered
#60
a sbc dd dosnt need to be broken in! just take er easy out of the shop then give er heck!
