BD Super B Single
Old 10-27-2009 | 10:28 AM
drp23's Avatar
BD Super B Single
Looking for Pros and Cons on this Turbo, power and cooling (EGTS). Thanks
Old 10-27-2009 | 05:45 PM
1882's Avatar
I couldn't be happier with mine, spools almost as quick as stock and cools my fueling mods easily, good for up to 50 psi boost. Some have laid down 500 hp with this turbo. Great towing turbo as well. I don't think you'll regret buying one, if it's not enough down the road you can always add the second BD & then have twins.
Old 10-27-2009 | 05:55 PM
drp23's Avatar
What extra turbo do they use for twins, another Super B or a Special or something else. Thanks for reply.
Old 10-27-2009 | 06:11 PM
DodgenIt's Avatar
Something else. Its their big brother turbo or something. I believe is about the same size as a s400. Or really close to it. I think.
Old 10-27-2009 | 08:46 PM
95ram's Avatar
The BD super B is an S300G (57/65/14). It's good for about 425 RWHP. Should spool instantly with the mods in your sig.
Old 10-27-2009 | 08:53 PM
drp23's Avatar
Hows reliability, is it a 100,000 mile aftermarket turbo?
Old 10-27-2009 | 08:56 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Lots of happy people using that turbo, very popular product.
Old 10-28-2009 | 09:44 PM
cumalong's Avatar
Is it possible to get this turbo with a 12cm wastegate? I need high altitude spool
Old 10-29-2009 | 05:51 PM
recklesskelly's Avatar
high tech turbo sells it with a 12 or 14 and now includes a downpipe to, HTBG is its name but it costs more than the super B. You can send your super B to them and have them mod it but its gonna $$$.
Old 10-30-2009 | 12:15 AM
DodgenIt's Avatar
Cumalong.. If you get a super B, take it to a diesel shop around you, show em its brand new, and see if you cant work a deal for swappin the 14 for a 12. It only takes 30 min to swap, and with the prices being so close between the two housings, they might be more then willing.
Old 10-30-2009 | 09:37 AM
jdjanetka's Avatar
I put a super b on and wasn't quite happy with the spool up so I changed to a 12cm housing from Gillette diesel(great people to deal with) and am very happy with it now.Should have gone with the htbg first and saved some money.It seems the only difference is that the htt doesn't come with a downpipe which you'll need. Just saw the htbg cheep here(http://www.gautoparts.com/product_p/htt-1x57257.htm). The picture isn't right so I would call and confirm it is the right turbo.
Old 10-30-2009 | 10:38 AM
drp23's Avatar
I have a Super B and wonder what you gain or lose with switching housings for towing, should I leave the 14mm on or switch to 12 also. Thanks, remember It's for towing.
Old 10-30-2009 | 05:24 PM
a 12 would spool slightly faster but not flow as well on the exhaust side causing egts to go up somewhat. The only reason cumalong wants a 12cm housing is he lives at elevation where it is harder to spool a turbo, you live at sea level and should have no trouble spooling that turbo with 100hp sticks. If i were you I'd keep my 14.
Old 10-30-2009 | 05:33 PM
drp23's Avatar
Thanks again.
SlingShot
04-04-2011 09:05 PM
Diesel Dave2
16
12-20-2008 08:11 PM
matt02dodge
02-25-2006 10:44 PM
Buckshotmckee
04-19-2005 08:20 PM
Saxet Nomad
05-26-2004 07:48 PM
