BD Race Anti-Defueler BD RAD
Old 02-03-2005, 10:41 AM
OPIE's Avatar
Originally posted by 600 Megawatts
Here is a question, would an earlier year ECM, say a 2000 work in my 2001 or would it be engine code city??? I really need to get rid of this defueling.....
Kevin
No Sir, If you try that your truck will start idle rough and set some codes and give you a check engine light.
Old 02-03-2005, 10:46 AM
OPIE's Avatar
. And diesel trucks have a clutch and lots of gears!!!
Kevin
But most of you guys only pull the sled with one of them.
Old 02-03-2005, 08:51 PM
greenworks's Avatar
The way I understand the edge drag comp is that it won't defuel or is that only on gears 3-5, Joef... I tried the 3rd gear again today and made mr clutch mad I seem to get going really well in 2nd anyhow
Old 02-03-2005, 09:11 PM
paulb's Avatar
In my truck (it's an auto), it would defuel at about 22psi in 1st, and 2nd. I normally launch at 15psi, but right after launch it would bog. I could power brake it to 22psi (only do this if you have billet shafts or want billet shafts ), and as soon as it hit 22psi it would surge really bad, as it would defuel. Putting the RAD in dropped my E.T. by ~.64 seconds. It may only work for an automatic, but in my installation manual it says only hook up the TC wire on an automatic.... Leads you to believe that it does something for manuals.
Paul
Old 02-04-2005, 08:45 AM
Muted User
600 Megawatts's Avatar
HUmm, thats good info Paul. I am gonna call em and see if the will work with the manual..
KP
xloudnproud
05-02-2006 11:59 AM
abc4yew
16
10-19-2005 02:59 AM
hellotbone
01-28-2004 11:52 PM
StakeMan
34
07-07-2003 08:17 PM
Quick Reply: BD Race Anti-Defueler BD RAD
