BD auxillary lift pump
Old 07-07-2008 | 11:05 PM
cumalong's Avatar
I am thinking of buying the BD aux lift pump in conjunction with my intank (mfg warr) one. Anyone have any thoughts. I am not looking to push a ton of fuel. Maybe someday some mach 1.6s. Anybody have input on this decision.
Old 07-07-2008 | 11:24 PM
98.5Hotrod's Avatar
I've been running the same set up for at least 1.5 yrs, 20psi at idle, and even with my mods have only been able to pull it down to 12psi at WOT.
Old 07-08-2008 | 12:49 AM
dodge_24's Avatar
where did you install the fuel pump was thinking of going that way but ive heard that the intank pump would be to slow to keep up with the pusher pump
thanks
Old 07-08-2008 | 01:27 AM
totalloser's Avatar
I thought the in tank was not compatible with a pull type pump due to the open discharge of the in tank pump back to the tank. The idea being that the aux pump would pull air from this port pushing air through your system. That's why most setups like this are forced to use a "draw straw".
I know this is the usual recommended method of getting by the in tank pump. At least on the 2nd gen stuff like mine.
Old 07-08-2008 | 10:42 AM
Tiger Rag's Avatar
My BD kit worked well while I had it. Good fuel pressure with it for reasonable $. Bullydog also makes a nice kit. There are plenty of ways to configure a pusher system including making your own with a relay.
I pulled mine out when I put a cam in and the mechanical 12v lift pump. I wanted a truely bulletproof system.
Old 07-08-2008 | 10:49 PM
cumalong's Avatar
Wow, I did not know about the air issue. Sounds like I better look at something other than an auxilllary pump. Maybe the airdog. Just dont like spending more than have to.
Old 07-08-2008 | 11:37 PM
98.5Hotrod's Avatar
You won't have any trouble with it, mine works fine and i'm pushing 450-500rwhp.
Old 07-10-2008 | 05:50 PM
mattpatt's Avatar
i put one in about a year ago and its worked great i've had no problems with it at all
supr
31
05-27-2008 01:36 AM
Ramblin Rebs
06-15-2005 09:18 PM
duallydave
05-18-2005 10:07 PM
Outlaw_Frog
07-02-2004 07:49 AM
DF5152
24
01-04-2004 06:57 PM
