BANKS OTTO MIND
BANKS OTTO MIND
I HAD A BANKS OTTO MIND HOOKED UP AND IT FRIED MY INJECTOR PUMP. $1800 LATER I AM WONDERING IF THE OTTO MIND CAN BE HOOKED BACK UP WITHOUT SPLICING INTO THE INJECTOR PUMP. WHAT I AM LOOKING FOR IS THE INCREASE IN TQ AND HP WITHOUT MESSING WITH THE PUMP. I HAVE A K&N AIR FILTER, 4 INCH PIPE AND LARGE WASTE GATE.
THANKS,
DAVID H
THANKS,
DAVID H
Re:BANKS OTTO MIND
Get rid of the Banks stuff.
Also, get a fuel pressure gauge and make sure to monitor your pressures (so you are not starving your pump for fuel).
Also I suggest an Edge Comp or Edge EZ.
And a set of mild injectors.
The larger wastegate you have doesnt really do anything to add power to your truck.
--Justin
--Justin
Re:BANKS OTTO MIND
Ditto with the above post. I've got a COMP on mine hooked up as an EZ (didn't tap the pump wire) and the truck runs great. Real easy to take on and off. It's so easy I did it at night in a Wal-Mart parking lot for fun.
Once I get tranny mods, I'm going to hook up the wire and really enjoy the power of the comp (adds ~120 hp). ;D
![Laughing](https://www.dieseltruckresource.com/forums/images/smilies/laughing.gif)
bradmulvey
14
01-27-2006 12:18 AM
