BAHF heat shield
Old 03-21-2008, 01:24 PM
MATTIEBOB's Avatar
Here You Go. Its Not That Hard To Make I Just Made A Cardboard Template Traced It Out On The Aluminum I Used A Plasma Cutter To Cut It Out Set It On A Straight Edge(angle Iron) Heat It With A Torch(low Heat) And Slowly Bent It. Slipped My 4.5in Od Aluminum Pipe In And Took It To A Shop To Have It Welded Because I Not Very Good At Welding Aluminum. It Took About 30min To Form If You Dont Have A Plasma Cutter You Can Use Cut Off Wheel On A Air Grinder. You May Also Check At Local Vocational Schools.
Attached Thumbnails BAHF heat shield-amsoil.jpg   BAHF heat shield-amsoil3.jpg
Old 03-21-2008, 01:32 PM
12VBLacKCLouD's Avatar
Thank you Nate. There is a lot of air moving under that hood at freeway speed. Sorry, the shield is more for looks than function, mine works fine without one.
Old 03-21-2008, 01:59 PM
DTR's Cow Boss
DodgeCowboy's Avatar
Hey bud! so ya I guess I will pop in on this have you thought about water? getting the filter wet because I know were you live I lived there my self and my side of oregon gets its amount of slush and snow and water and thats kept me from doing the bhaf
Old 03-23-2008, 02:23 PM
Simple fix, extend the hood wheather stripping 4 inches right above the filter, if thats not enough, get/build a shield for it.
Old 03-23-2008, 02:24 PM
Deezel Nate's Avatar
Black Cloud it will get hot enough to melt an outerwears.
SO, the shield keeps super hot air out of the filter and also keeps the outerwear from melting.
You could paint your truck pink and call it the Edit wagon for all I care, but just because you think it's a certain way, doesn't mean it's always right
Cowboy, the outerwears is what most people put on the filter. It is water proof I guess.
Old 03-23-2008, 11:40 PM
This is a family forum. Keep it clean. Outerwear covers are a waste of $30 imo, because the elastic band wears out quick, even if they are Water Resistant and keeps the filter clean longer. Its a $30 BHAF anyways, im gonna replace it in 10K. Ill build a shield eventually. Sorry if I came across with that narrow mindset...
Old 03-31-2008, 07:41 PM
xp8103's Avatar
Aluminum sheet
Where are you guys sourcing it for the shield?
Old 04-01-2008, 05:25 AM
DetroitDiesel71's Avatar
Location: Dayton, NJ (temporarily while In USCG on Staten Island)
stainless can
Someone threw out a perfect new stainless can, I die cut, installed lid and it fit perfect, I am putting the image in my gallery, I ll post when it is in for you.
Old 04-02-2008, 05:59 AM
pic of bhaf
remembered how to post attachment. Here is a pic of the heat shield for my bhaf. I just need to finish up the metal work to connect it directly to fenderwell
Old 04-02-2008, 07:12 AM
xp8103's Avatar
It looks like a piece of shiny stove pipe!
Old 04-02-2008, 08:33 AM
actually
yea it was a heavy shop stainless can that the lid rod had bent on, so their trash, my gold
branhay
11-20-2005 11:01 AM
Palmetto_kid
09-06-2004 10:03 AM
psdctd
02-24-2004 12:58 PM
Cumminsdude
13
08-04-2003 05:56 PM
boehunter49
03-06-2003 05:27 PM
Quick Reply: BAHF heat shield
