BAHF heat shield
Old 03-20-2008, 11:40 PM
Krob's Avatar
BAHF heat shield
What is the best material to use to make it and any advice on how to do it. I found the diagram in the tech articles about how to make them however it doesnt give me anything besides the template...or am i just stupid and did not find it.
Please derect me to were this has been covered before because i am sure that is the case if you please.
Thanks Rob
Old 03-20-2008, 11:48 PM
12VBLacKCLouD's Avatar
22 gauge aluminum or steel if you want one. Ive ran without one for 2 months, guys on here have ran without for years. I don't see a point as long as your not towing.
Old 03-20-2008, 11:54 PM
12valvesmoke's Avatar
i made my own.. its actually really nice. i used thin stainless steel with flat black paint over it.. then on the edges i sliced fuel line and stuck it over the top and the back and where the air filter tube goes by it then i put gasket maker in between the tube and the heat shield itsleft so it looks more clean and un homeade haha.. i put a piece of plywood down to cover the three bolts that stick out of the finder that also gives a good surface for the heat shield to be screwed in to. i takes a lil time to make sure you get all the corners right and it doesn't rub on anything but i was really happy the way mine turned out.. hope this helps at least a little bit, just lettin ya know you dont need the template to make it.
Jared
Old 03-20-2008, 11:58 PM
Deezel Nate's Avatar
I'd say 22 guage is on the thin side. I'd use either 16 or even 14 guage. I need to make mine sometime. My friend works at an HVAC shop, so it will be cake to cut and bend it on the equipment over there.
Old 03-21-2008, 12:15 AM
Why the extra weight? Its an airbox... you dont even see a direct diffrence in egt's. Maybe 100 degrees if your towing.
Old 03-21-2008, 10:43 AM
Krob's Avatar
alright are there any that i can buy since i dont have the fab skills needed.
Old 03-21-2008, 10:44 AM
xp8103's Avatar
http://www.cumminsdatabase.com/marke...=listing&id=45
Old 03-21-2008, 10:45 AM
xp8103's Avatar
I dont have any connection to the link above, just came across it while looking for pictures...
Old 03-21-2008, 10:51 AM
Krob's Avatar
Is this the guy who took the free design and was trying to sell it here a while back?
Old 03-21-2008, 10:52 AM
xp8103's Avatar
Honestly guys, I have no idea. Apologies if he's been zapped for it. Just trying to help out a guy who asked.
Old 03-21-2008, 11:55 AM
MATTIEBOB's Avatar
I Made Mine Out Of Treadplate Aluminum
Attached Thumbnails BAHF heat shield-100_9531.jpg   BAHF heat shield-100_9533.jpg
Old 03-21-2008, 11:57 AM
xp8103's Avatar
How about a pic installed?
Old 03-21-2008, 12:29 PM
Krob's Avatar
How hard was it to build and what all in the way of tools did you have to have. I am no Fab guy so i might have to ask a buddy.
Old 03-21-2008, 12:31 PM
xp8103's Avatar
How big a piece do you need?
Old 03-21-2008, 01:16 PM
Seriously... you drive a 7000lb plus truck and you are worried about the 1 or 2 lbs that this heat shield would add?
Quick Reply: BAHF heat shield
