bad results after GSK!
Old 12-23-2005 | 12:38 AM
12valve's Avatar
Unhappy bad results after GSK!
I just installed a 4k gsk today...
i have done that about 4 times yet...each time it worked out fine!
but today i started it up, after everything was done, reved it up, to see some 4000 rpm, but no good results... poping and missing like crazy. it wouldnt go past 2000 rpm! it just misses and pops and shutters!!!!
i dont think ive done something wrong, since i checked it again, everything seemed right. anybody could tell me the problem???? Cant use the truck like this! Just finished the twins today! cant use them like this!
Old 12-23-2005 | 05:29 PM
luke h's Avatar
poping
I put a 4k kit in my old 84 and it did the same thing, i advanced timing to 19.5 and it helped a little maybe 3000 in gear was all it ever saw and in park 3300 or so before the sputter i researched it all the time and never found a cure so good luck man. Anything from an air leak in the fuel line to the little cam in my 160 hp pump could have cause it as far as i know.
Luke
Old 12-23-2005 | 05:32 PM
luke h's Avatar
poping
94 i mean
Old 12-23-2005 | 05:34 PM
luke h's Avatar
twins
you could sne me the twins and ill tell you how they work out
Old 12-23-2005 | 06:11 PM
MasseyMan1089's Avatar
was the engine hot? I have the 3k gsk and it wont do that if its cool, or cold, it has to be hot...
Old 12-23-2005 | 08:25 PM
got...DIESEL?'s Avatar
make sure your AFC boost line isn't broken from taking that housing on and off...it'll keep the AFC from pulling out of the way and defuel it enough to not achieve rpm or normal boost numbers.
Old 12-23-2005 | 09:26 PM
12valve's Avatar
it did the same thing with the afc off! (set aside)
it happens only from giving too much fuel, when i hold down the fuel shut off solenoid a bit, so it cuts the fuel kinda off, the missing disapers, but of course no power then!
Old 12-24-2005 | 12:02 AM
1320's Avatar
I almost left in the small oem spring once.....I don t know what it would do, but are you sure you removed all the oem springs?
Old 12-24-2005 | 12:05 PM
12valve's Avatar
i removed ALL the springs and shims. then replaced it with the new seat which comes in the 4k gsk and thightened it up the way it should be!
Old 12-24-2005 | 12:50 PM
John Faughn's Avatar
This maybe more of a ? than an answer , but when working on gassers the poping from the intake was not enough fuel and poping from the exhaust was too much fuel , I haven't done enough moding with the diesels to have that symtem yet, and was wandering if that was possible when reading the post and other mentioning poping.
Old 12-24-2005 | 01:37 PM
ihpower's Avatar
i am in a lot diffrent boat with my truck but when i was messing with the fuel screw on my truck it unscrewed it to far and it was not getting enough fuel. To me it sounds like it is not gettin enough fuel. BUt taht is just me
Old 12-24-2005 | 01:45 PM
mr T's Avatar
ur timing needs to be advanced....ur plate profile on the #4 may also not be the most 4k gsk friendly but im just speculating there
Old 12-25-2005 | 12:58 AM
12valve's Avatar
NOW IT WORKS!!!!!!
found the problem! i cleaned the air intake from the inside, (just before replacing the gsk) to see if it would get dirty, with some cleaning towels at once, one was left inside, and clogged before (on) the turbo blades it got only bout 5% of air, to burn that much 215 fuel!!!
hope to have a happier xmas now...
thank's to y'all for the replies and for the friendly help! i tried what you suggested, untill it was something completly else...
siebertl
06-10-2007 02:29 PM
SHARPMACHINE
03-06-2007 08:45 AM
plow
08-09-2005 04:25 PM
MR HYDROSEED
03-09-2005 10:49 PM
Got Smoke?
10-26-2004 03:57 PM
Quick Reply: bad results after GSK!
