bad day
Old 01-19-2008 | 05:24 PM
  #31
IntakeRacing's Avatar
Originally Posted by bullboy85
ok no pulling anymore but lights are still on after i replaced the sensor.
did you check to make sure there wasn't a break in those wires going to the rear speed sensor (the one you changed)
Old 01-19-2008 | 05:27 PM
  #32
bullboy85's Avatar
i fallowed it as far as i could and saw no break, if it was broke wouldnt my speedo not work though?
Old 01-19-2008 | 07:02 PM
  #33
it would still work. your gonna need a digital voltmeter and do a continuity test on teh wires.. jumper the 2 wires together at the sensor and then follow the wires all the way to the front of the truck and test them there.
Old 01-19-2008 | 07:09 PM
  #34
99globalwarmer's Avatar
check all the plugs for the abs mine came on earlier this week and i found that the passenger side plug bellow the turbo came unplugged. plugged it in then no more light abs worked
Old 01-19-2008 | 10:45 PM
  #35
bullboy85's Avatar
wouldnt that be for front abs? i thought the only one i had was in the back, no front abs. ill try the continuity test maybe tomarrow if i have time. im kind of worring it might be something worn with the wires under the dash, had alot of electrical problems with the truck when i got it, that of corse i wasnt told about!!!! already spent around $1500 on just getting that all fixed, imagen what i could of done with that money!!!
commonrailkid04
01-12-2008 12:20 AM
65fury
25
04-06-2007 09:16 AM
Buckshotram
01-09-2006 10:27 AM
C Pierce
03-21-2005 09:41 AM
doomgaze
02-06-2003 07:51 PM
