Bad Boost Leak
Old 03-30-2006 | 06:56 PM
01smoker's Avatar
Bad Boost Leak
Just installed my gauges the other night and with a Drag Comp, 150 hp sticks, and a Edge boost elbow I am only hittin 28 psi. I was told I should be hittin more than that. So I checked my intake horn and grid heater gaskets, and made sure all of my boot clamps were tight. The fittings for my boost line were sealed with thread sealer. I don't know where else to look. I don't if this is normal or if it matters but I can hear a sound coming from my boost gauge. Not real loud but I can hear something in there. Any help would be appreciated.
Old 03-30-2006 | 07:01 PM
Geico266's Avatar
I think 28 is pretty good with a stock turbo, but I'm no expert.
Old 03-30-2006 | 07:31 PM
STACKED's Avatar
i would check out your gauge, it should be higher than that i get close to 40psi with stock turbo.
Old 03-30-2006 | 09:33 PM
scottsjeeprolet's Avatar
Make sure the waste gate is still hooked up. mine came off and i couldn't get it over 20psi either. you can only see it from under the truck on the bottom of the turbo.
Old 03-30-2006 | 10:34 PM
Geico266's Avatar
I can only get 25 PSI with the tube at the elbow piched off. You are saying the is not normal huh?
Old 03-30-2006 | 10:45 PM
gsdog1's Avatar
Pressurizing the system and going after it with a spray bottle of warm soapy water works great.
In order to do this you will need an air compressor with a regulator, and will have to fab up essentially an end cap to fit over your turbo inlet. I posted on this a while back and walked through it all on that. Your local hardware store should have what you need. 4" rubber boot (id), 4" pvc pipe 4" long, 4" pvc cap, and one quick disconnect.
Take the inlet hose from the air filter to the turbo off, affix the gadget to it, crank down on the hose clamps that should come with the boot (this is now a pressurized fitting, where as in normal use, the inlet side to the turbo is in a vacuum state). Why do I know this? It will come chasing after you otherwise.
Hook up your air compressor, and regulate the pressure down to 10 psi. Then spray everything with the soapy water.
Good luck!
hardheaded
04-03-2008 10:43 PM
65fury
25
04-06-2007 09:16 AM
Erska
01-13-2007 01:48 PM
Buckshotram
01-09-2006 10:27 AM
C Pierce
03-21-2005 09:41 AM
