Bad Bad Bad Day!!!!
I would get your timing set up correctly first by using the dial indicator/plunger lift method this is the most accurate method. This will make it easyer to work out your other issues and could help save you from blowing a headgasket,burnt piston, etc. When setting the timing/plunger lift for your pump you use the cpl number to get the correct lift amount all engine/pumps are not the same. Their is a chart that will give you this info on the piers web site.I have mine set up at 17 and it works well for me anything in the 15-17 range seems to work well for most people.
The reason I didn't say anything about the plunger lift method is that he does not know if it has the stock pump or not.... He will have to find out what pump he has first. The timing by dampner is not quite as accurate but so long as you are not splitting hairs it's fine. 1mm = 1.974* So 2* per mm is close enough and easily enough measured.
It is always better for a guy to know how to set it up correctly so that if it does not work out when playing around with other methods he can still get himself back to a standard base line.
yep thats the diesel place, they were real nice, but after i got my truck back from them working on it they said it was real peppy and had crisp throttle response , it was horrible, it had no throttle response, barley ran, smoked excessively and was unsafe to drive, i smoked out every vehicle that came close to me and the coolants temps would never cool down, it kept boiling over. im afraid to look at the pistons, i bet every cylinder is scored now and i probably have a layer of unburt diesel an inch thick on the pistons
, and i won't be taking anything back there, for fear the will break something. thanks guys for youre help and support.
jason
jason
commonrailkid04
01-12-2008 12:20 AM
2500TurboDodge
04-07-2005 02:49 PM
