Baby Got (boost) Back!
Solved my boost problem!
With my setup 100hp (ATS) injectors, Drag/Custom Comp, PDR hx40, and ats Manifold.
For about the last 6 months I have noticed a drop in boost pressure that has kept getting worse.
Originally I was hitting 39-38 psi with my PDR 40/16.
Lately I checked my turbo (when I installed my O ringed head).
It was in excellent shape and spun like it was still new and had no play.
Also mid throttle boost was long to come up and somewhat sluggish.
I also checked my boost gauge line, it was fine.
I check all my intercooler boots, all looked good, plus I went ahead and tightened them up a bit.
So I figure what the hell, I install a restrictive wastegate elbow that I had laying around.
I did, and the results are great!!
The mid throttle responsiveness is back, I can easily hit 24 psi now with my Edge box OFF.
Before I was lucky to hit 20 psi.
On a WOT throttle run over 100mph I was able to hit 40psi and maintain it, before it was 31psi.
On a run in WOT with OD cancelled I hit 43psi, this turbo really sings now!!
I know over 40 is dangerous, so this weekend if I dyno I might just have to put the open elbow back on.
So is the wastegate actuator worn out??
--Justin
--Justin
Re:Baby Got (boost) Back!
I had the stock free-flowing elbow that PDR supplies with their HX40 turbo.
Piers sets his wastegates to open at 38-40 psi.
What I think is that the wastegate actuator began to wear out, and was opening prematurely.
The elbow I have installed now is the brass unit that Edge and other fueling box manufacturers supply with their fueling boxes to delay the opening of the stock set/factory wastegate.
--Justin
--Justin
My problem is different. My boost numbers are getting higher. I still have the HX 35 and usually it hits 36 psi with no problems. Lately,
it has been hitting 42 to 44psi. What would cause this??????????????
jmccart
05-01-2008 12:12 AM
TheMighty'67
03-22-2008 09:48 PM
JoshPeters
04-03-2005 08:13 AM
