B2 Specs ???
B2 Specs ???
Anyone know the turbine wheel specs/dimensions of a B2??
Have a project fixing to get started, but I want to know if it will even work
Thanks in Advance,
Chris
Thanks in Advance,
Chris
Yep, twins @ 57psi on the dyno, stock injectors, and ~13* timing (stupid slippy shaft )
I had plenty of fuel too, I usually see 62psi (pop-off limited) on the street, and that's limited BIG time I saw 69psi before I re-adjusted the pop-offs!
I need a wastegated primary
Chris
Chris
That's alot of boost for 400hp. Sounds kinda odd. 13 deg of timing is gonna hurt. If you have one that slips, it's best to take it out and stone the taper with a small sharpening stone. Then go up inside the gear and check for defects. Usually can get those with a piece of oiled up 400grit and your finger. I was just curious, thanks.
Ron
Ron
06RAMCTD
0
12-19-2006 05:15 PM
