b-d auxillary fuel pump kit???
hi guys,im in need of a pusher pump real soon,i was looking online and seen b-d diesel has a auxillary pump kit with all the goodies to mount it and conect the fuel line and also a wiring harness,has anyone tried it?it looks good and says its good up to 600hp.i got my injectors from them and got great service,just wondering if anyone has good or bad experience with the kit.thanx.
I have installed them, easy to put in and they work good, only downside is if your stock lift pump is going out you would need to replace it also. The BD pump is designed to work in conjunction with the stock lift pump, so if your stock pump needs to be replaced, it would be more cost effective to install a FASS system and be done with it. The cost of both a stock lift pump and an auxillary pusher would cost almost as much as a FASS.
supr
31
05-27-2008 01:36 AM
1320
11-02-2005 11:36 AM
