Automatic Down Passenger Window
Ok. My little mind is working again. I was wondering if I could use a relay, triggered off of the wire that rolls the drivers side window down automatically, to roll down the passenger window as well. What do yall think? It seems like it should be fairly simple.
1 Post
Re: Automatic Down Passenger Window
Well, here's how I think it would work. You've got your constant hot wire coming from a key on only source (that way the window only has power when the key is on). Then you've got the power for the drivers side window triggering the relay. The relay then energizes the wire from the passenger side switch and rolls the window down. At least, that's how it works in my head. I only roll down both windows at the same time so it wouldn't be a bother to me if every time I rolled the driver down, the passenger went down as well.
If the circuitry is built into the switch, how about just getting a replacement driver side window switch,
and hooking it up in place of the passenger window switch, right next to the driver side switch?
Hit both switches to the auto down position and voila!
phox
phox
phox, I'd like to do that, but I'm looking for something cheap and simple. I am in college you know. I'm gonna look into it more tomorrow during my lunch break and I'll let you know what I find.
Tyler just do what u were explaining and if you need the pass. window up then you can roll it up just by the other switch. I have seen people do it and i have done it b4 its not very hard but would i would do is find the rely for the autmatic part of the switch and tap into that and run a wire across to your other switch which doesnt have a rely (or it shouldnt atleast) and then you can still roll your window down seperatly if need be but also you can then push your switch further down and once it hits auto roll it will then roll the other one down. Im sure you have already figured it out by now but just tryin to help ya out. If i have confused u then let me know.
Could I put an auto-down switch out of a newer truck in my 95?
Or should I try it and let everyone know!?
BTW, is the passenger side auto-down as well (I mean the switch in the passenger door, not the passebger side of the driver door switch.)?
Thanks Guys,
Chris
Thanks Guys,
Chris
bigblue,
i'm not an expert at this by i did make a living when i was younger doing this aftermarket radios, amps, alarms, starters and the like. i have put in "auto rolldown" setups in cars that don't have them in at the factory. the one install that i do recall is a 89 ford bronco. the customer wanted an auto rolldown for the large window at the tail gate. it was done but with three relays and the trigger that set this off was from the three function remote off the car alarm. was quite involved.
just my $.02
just my $.02
I don't know how I'm gonna do it quite yet. Still looking for info. Work is really starting to crank up so this project might have to get put off until school starts back up again. I'll keep yall posted.
Oh there are lots of those. But they get awfully expensive and I'm having trouble finding one that is fine with my truck coming before her. I had one at one point in time. Don't know why I broke that off.
I've dissected window switches with auto down, all it is a full on switch at the far movement rather than the momentary on type normally used. The stays on portion of the switch has a metal strip that the current flows though, the higher amperage and heat when the window bottoms out causes the strip to move kicking it off. It's almost like a self resetting circuit breaker. A very simple device.
